Running higher rev limits reliably
okay, now that I have had a chance to go through the replies, it appears that it doesn't make sense to be able to rev that high (yes, I used to own an S2000) without a bigger turbo and some serious machine work.
As mentioned, being able to rev that just allows me to hang in 3rd and 4th longer and doesn't require me to shift mid-bend, where I run out of 3rd or 4th. I'm not getting it to get the 9000 rpm kick that I got out of the F20C engine.
As such, I'll be saving up for a 20G LT or FP Green and some decent coilovers, seats and a proper harness.
Yeah even with the FP Green, 8500 seems well out of range. Going that high is for GT35Rs with some serious cams. When I went to the track and shifted at 7500rpm, I went consistenly slower than when I shifted at 7300. Stock turbo of course.
No, it means the rate of acceleration is on the decline.
Regardless of whether one has a 5 or 6 spd, a shift point calculator reveals that point whereby spinning it faster means going slower - for each gear change. If one has a copy of his dyno sheet and knows his gear ratios, it takes about 10 minutes to get the facts.
I may be a turbo noob but it seems like there's not much pull after 5k. These things aren't V-tecs that need 7k plus for any power.
