Ebay Oil Filter Sandwich
Old Mar 3, 2007 | 05:50 AM
Jeovannie's Avatar
Question Ebay Oil Filter Sandwich
What do you think about this guys?
http://cgi.ebay.com/ebaymotors/LANCE...QQcmdZViewItem
Old Mar 3, 2007 | 05:56 AM
BuLocal's Avatar
Looks interesting, but you never know with that stuff until someone tries it........
Old Mar 3, 2007 | 06:02 AM
kmcconn9's Avatar
This looks to be a knockoff of the graddy oil adapter. The problem with this is that it brings the oil filter closer to the ground, as well as the lines you have coming off of it.
Old Mar 3, 2007 | 06:12 AM
reggiesd's Avatar
i was about to bring that up coz i just changed my oil 2 days ago and that oil filter is pretty much almost as low as my downpipe was...especially if you're using the mobil1 filters which are longer than the oem ones.
Old Mar 3, 2007 | 06:17 AM
Jeovannie's Avatar
i didn't know about the greddy one
Old Mar 3, 2007 | 06:52 AM
gsrboi80's Avatar
+1 I wouldnt use this on an EVO for that reason alone. You dont need the filter any closer to the ground than it already is
Old Mar 3, 2007 | 10:08 AM
D_Eclipse9916's Avatar
dont use ebay stuff for things like oil...
Old Mar 3, 2007 | 10:35 AM
EVOlutionary's Avatar
I have the Greddy/Trust one. It works great for my oil pressure gauge sending unit. Have not hit the ground and ripped the filter off the engine yet, but it could happen if you run over something. With this, the filter is the lowest point on the car. . .
EVOlutionary
Old Mar 3, 2007 | 12:19 PM
riceball777's Avatar
they all work the same and all work great. but i would not use one on the evo bevsuse it will lower the oil filter and the evo already has ports on the oil filter housing for a oil temp and pressure sender.
Old Mar 3, 2007 | 12:30 PM
hotrod2448's Avatar
correct me if I'm wrong but isn't the oil filter mount already tapped for temp sensor?
I'm pretty sure I saw a pipe plug pretty close to where the oil cooler lines run in.
Old Mar 3, 2007 | 01:26 PM
trinydex's Avatar
just use the factory ports...
Old Mar 3, 2007 | 01:55 PM
Jeovannie's Avatar
EVOlutionary
do you have a picure of your set up?
Old Mar 4, 2007 | 02:50 PM
jbrown's Avatar
You are correct, most people are unaware of this little gem!
spread the word!
Old Mar 4, 2007 | 02:52 PM
Ultimate CC's Avatar
I sell the prosport one which is a pretty sweet unit, i suggest using a smaller filter to avoid the issue of clearance...they are currently backordered though...
Old Mar 4, 2007 | 02:53 PM
LetItBreath's Avatar
From: City O Sin, MA...the not so sinish part though...
Yea, this thing seems kinda useless. I have an aftermarket oil temp and pressure sender on the filter housing and never needed this. Whoever designed this didn't do their homework...
