turbo flow numbers
Old Mar 3, 2007 | 06:48 PM
purevibez's Avatar
turbo flow numbers
does anyone know the flow numbers in cfm and lb/min on:
gt35r-
gt3065-
50trim-
20glt- ,47lbs
and any variant of the above ie the new 35r and ball bearing, non ball bearing if there is any diffrence. searched but couldnt find anything. thanks in advance.
Old Mar 4, 2007 | 08:08 AM
kjewer1's Avatar
The 35R comp wheel maxes out around 65 lbs/min.
3065 will be the same, since it's the same comp wheel. Smaller turbine side however, can hurt power when trying to max out the comp wheel.
50 trim maxes out at 50-51 lbs.
2glt maxed out on my car at 49 lbs.
Stock EVO 3 and 8 turbo maxes out at 42-43 lbs for reference.
Old Mar 4, 2007 | 08:28 AM
purevibez's Avatar
thanks alot kjewer1 i appreciate the help and info.
