projected dyno numbers???
Old Mar 4, 2007 | 08:02 PM
fast03evo's Avatar
I am currently building up a 03 evo and am wondering what kind of power I will put down at the end of this LONG!! journey.
Fresh rebuilt stock shortblock w. eagle rods
ARP rod, crank, and headstuds
stock CI
big FMIC
660 CC injectors
3inch turbo back
ported manifold
white rabbit turbo
272 cams
Meth.
Old Mar 4, 2007 | 08:05 PM
brute_nm's Avatar
What boost and what altitude are you at?
Old Mar 4, 2007 | 08:07 PM
EvoRecordSetter's Avatar
go dyno and find out
Old Mar 4, 2007 | 08:13 PM
fast03evo's Avatar
im in PA. dunno the alt. 23-24 pounds
Old Mar 4, 2007 | 08:14 PM
EvoDan2004's Avatar
meth and cams you can push up tord 28psi. if the turbo will do it. 24 is kinda underpowering your self.
Old Mar 4, 2007 | 08:19 PM
fast03evo's Avatar
i wanna be safe for a while. i know the meth can really push it and the turbo can def handle the boost. i will eventually push it there.
Old Mar 4, 2007 | 08:21 PM
EvoDan2004's Avatar
360ish maby i guess
Old Mar 4, 2007 | 08:23 PM
520hpsti's Avatar
you rebuilt the block but didnt do forged pistons?
Old Mar 4, 2007 | 08:29 PM
fast03evo's Avatar
"Budget Build" my goal is to spend less then $5K and hit 420WHP (the $5K includes the cost of the car, fixing it and a semi built motor)
Old Mar 4, 2007 | 08:30 PM
520hpsti's Avatar
ah i see.
Well good luck with the rest of the build, should definetly be a quick car.
Old Mar 5, 2007 | 08:46 AM
spoolint78's Avatar
good luck bro
Old Mar 5, 2007 | 10:49 AM
fast03evo's Avatar
well heres my numbers so far
cost of the car $750 (came with cams, 3inch turbo back and FMIC. boost controller, turbo timer and SAFC2)
longblock $1500
gaskets/misc $500
exterior parts $1800
turbo kit $700
With any luck. this may be going back together this week and running the following Cant wait.
