Cam install: Assembly lube needed?
Old Mar 6, 2007 | 08:13 PM
sparky's Avatar
Is it recommended to use assembly lube when installing new cams?
Old Mar 6, 2007 | 08:16 PM
CO_VR4's Avatar
Yes. Go with the cam manufacturers recommended lube.
Old Mar 6, 2007 | 08:17 PM
Cal City Evo's Avatar
It can't hurt sure is better than putting them in dry.
Old Mar 6, 2007 | 08:18 PM
hondafan's Avatar
i definitely would.
Old Mar 6, 2007 | 08:19 PM
AF-Evo8's Avatar
redline assembly lube is what i used
Old Mar 7, 2007 | 04:04 AM
Liqquid's Avatar
Comp cams told me No!!! I was very suprised. They said coat them with oil, and then I asked about the synthetic and they said that's fine.
Not in my car lol, I used moly (assembly) lube and changed the oil afterwords.
Old Mar 7, 2007 | 05:06 AM
EvoLutionized8's Avatar
Oil is recommended by Mitsu, then some assembly lube on the outsides.. the lobes should be coated with oil to reduce friction.. Good luck if Comp says "no"..
evoniners
Apr 28, 2016 07:42 AM
domorex
Mar 16, 2015 08:43 AM
bmojito
South Region
22
Oct 24, 2008 04:07 PM
dubbleugly01
12
Jan 30, 2006 01:33 PM
purecoda
Lancer Tranny/Drivetrain Tech
20
Nov 6, 2003 07:39 PM
