Turbo noisier after LICP swap?
Last week I swapped out the stocker for a Nisei LICP, the aluminum one. Now my turbo makes a ton of sucking noise between about 5lbs up to 0lbs of vacuum? Anybody else ever notice this after swapping in an aftermarket LICP?
my educated guess would be becuase its a larger diameter pipe and the turbos probably starting to spool a little faster now
That's it! My tuner tested for leaks everywhere because that's exactly what it sounds like. Glad to hear it's normal. Thanks!
its funny because a lot of new owners think you need to get a bov and vta to have your car sounding "srt-4 cool", your totally right a cone filter and boom you got all the noise you'll ever need
The short answer is yes & maybe - at the same time. Reason I can't simply say yes or no is because the car was tuned with 100 octane right after the LICP install. So basically I'm comparing a 91 octane tune without the new LICP to a 100 octane tune with the new LICP. I picked up 50whp and about 300RPM's of spool but who knows how much of that is the gas and how much is the new LICP. Hope that helps.
