HKS Cam Tests
Old Jun 3, 2003 | 01:46 PM
AMS's Avatar
AMS
HKS Cam Tests
I just got a shipment of HKS cams for the EVO8. We will be testing the cams on the dyno in the next few days. I have both 264 and 272 cams (intake and exhaust) and also a set of Demon cams to test. Stay tuned for cam results from AMS!
Regards,
Martin Musial
AMS
Old Jun 3, 2003 | 02:27 PM
ferrarokid's Avatar
cams
Hurry please ! ! are you going to try a 264 intake with a 272 exhaust ? ? ? please do ! ! ! !
Old Jun 3, 2003 | 02:57 PM
ShapeGSX's Avatar
Martin,
Are the HKS Evo cams hollow?
Also, I saw some nice gains on my 16G Eclipse with the 264s. I think that the Evo, with its better intake manifold should really do quite well with the cams!
Old Jun 3, 2003 | 03:27 PM
Turboniam's Avatar
Re: cams
I hope you guys will test out:
264 264 combo
264 272 combo
272 272 combo
Old Jun 3, 2003 | 05:41 PM
Blue Evo 8's Avatar
I'd like to see the results too.
Old Jun 3, 2003 | 07:34 PM
BADWRX's Avatar
Re: Re: cams
264 264 combo
264 272 combo
272 272 combo
Amen. I need to know for my JDM EVO VIII (SOrry, I just had to rub it in!) that I will be getting early next year!
Old Jun 3, 2003 | 08:03 PM
gtr's Avatar
gtr
I wonder if had mixed up the cams for some USDM evos I means we are seeing huge hp differences and perhaps some lucky people have jdm power. Anyways i'm interested to see the results.
Old Jun 4, 2003 | 12:34 AM
Mean TT's Avatar
Great news, I posted a few days ago about this exact same thing. I am assuiming that you will use adjustable cam gears to get the most out of the cams. Please post the dyno results. thanks for the little experiment!
Old Jun 4, 2003 | 07:12 PM
AMS's Avatar
AMS
Just got off the dyno with the car. HKS 272in 272 ex results: 353whp! and 330ft-lbs of torque. This was with boost hitting 25psi dropping to 23-24 quickly and then tapering to 20psi at high RPM's. I ran it also at 21psi peak and then dropping to 20psi at top end. The peak HP was about the same but torque was about 300ft-lbs. We've noticed that it will push about another 1psi of boost compared to stock cams so now we can hold a solid 20psi up top compared to 19psi before. For what it's worth I can safely say that the cams are good for a solid 25hp more at the wheels and about 20ft-lbs of torque, this would equate to about 30hp at the crank and 25ft-lbs of torque.
When putting HKS 272/272 cams on a DSM you will notice a huge difference in idle quality compared to stock cams. Here I was very suprised that idle quality was only slightly worse and there was not even a hint of stumble or off-throttle coast down dying (you DSM'ers probably know that well ) I'm very impressed with them and we're going to the track here shortly to see the results. Dyno graphs will be up tomorrow.
Thanks,
Martin Musial
Old Jun 4, 2003 | 07:35 PM
ez76's Avatar
What else was on the car besides the cams (and boost controller)?
Old Jun 4, 2003 | 09:08 PM
designmanfx's Avatar
oh yea!
Nice Info AMS... Looks like im ordering my cams pretty soon!
Old Jun 5, 2003 | 01:45 AM
ferrarokid's Avatar
Question cam test ..
Correct me if im wrong . . . these tests were conducted on a 1994 eagle talon ? with a 91' motor ? how can these results be accurately applied to the 46g in the evo 8 ? I know they use similar architecture, but do you think the gains will be the same ? idle quality ? are the static compresion ratios the same ? not trying to cause a controversy but would love to know the effects on a stock / or mildly modified evo ! ! !
Old Jun 5, 2003 | 06:25 AM
ShapeGSX's Avatar
Re: cam test ..
No, he did the tests on an Evo.
He also did a test on a Talon, previosly.
Old Jun 5, 2003 | 11:10 AM
AMS's Avatar
AMS
The test was done on our EVO 8, you must have looked at our site and seen the cam test we did on a 1G DSM. We took it to the track last night and pulled a 12.00 at 113.8 mph with a boost leak (one of the fittings I used to measure IC pressure drop lost a vacuum cap) and a slipping clutch. Also we did not spray the intercooler which gave me almost 1mph the last time I took it to the track. If everything was working correctly I'm confident high 11's and 115mph where attainable. We ran at Great Lakes Dragway and I'll post the video into a new thread.
Martin
Old Jun 5, 2003 | 11:18 AM
ferrarokid's Avatar
sorry for the mix up !! that is fuc*&#$ awesome ! !
