Titanium exhaust manifold......
how much s "minimal cost above ss ic pipes" and honestly how much weight would be saved if you did do LICP, UICP, mani, O2 housing, and downpipe? would it be worth it and how long would the parts really last under the heat and stress of driving? Just curious...
i had a yoshimura full ti exhaust system on my 600 superbike years ago. it was a beautiful work of art... for 2800$ and a six month wait
the blue the header turned after heat cycling was just awesome.
That would be the most likely piece(s) to sell. Within a normal disposible income and nice bling factor for the UICP.
Titanium would be a very bad idea for intercooler piping. I dont know what the technical term is, I'm tired, but Titanium doesnt have nearly the cooling properties aluminum does.
WHICH STAINLESS TO USE?
Within the 300 series of stainless steels, there are four types that are suitable, available and cost effective for the racer. These are 304, 316L, 321, and 347.
321 and 347 are known as stabilized grades of stainless. These are alloyed with either titanium (321) or columbium (347), both of which have a much stronger affinity for carbon than does chromium at elevated temperatures. This eliminates carbide precipitation leaving the chromium where it belongs for corrosion protection...remember our discussion of intergranular corrosion? Both 321 and 347 are top choices for exhaust headers, especially turbocharger systems and rotary engines. Since 321 is much more available than 347, that leaves 321 as the first choice, with no sacrifice in needed qualities.
316L is an extra low carbon (ELC) grade of stainless that has only .03% carbon, making less carbon available to precipitate with the chromium. It is used extensively in marine exhausts where salt water corrosion mixed with diesel exhaust particulates and electrolysis create such a horrible environment that even other grades of stainless cower and run away!
304 is the most inexpensive and available stainless in the 300 series. It is suitable for normally-aspirated header applications, and has been successfully used by many racing teams. It does not have the high temperature fatigue resistance that 321 does, but is considerably less costly and much more available. Most 304 tubing these days has the dual designation of 304/304L.
Practically speaking, there are overlapping applications of 304 and 321 stainless in header construction, but knowing you've got the insurance of the aircraft-grade 321 for the job is definitely worth consideration of the extra cost... if your application requires it.
Stainless steels come in both tubing and pipe sizes. Since certain pipe sizes are almost identical in dimension to tubing sizes, pipe may sometimes be substituted for tubing, and vice versa. Numerous wall thicknesses are available, but for headers, normally .049" (18-gauge) to .065" (16-gauge) is used.
Different specifications are used to meet particular requirements for the military (MIL), the American Society of Testing Materials (ASTM), and the Society of Automotive Engineers (SAE). Examples of what to look for when you order stainless tubing are as follows:
ASTM A-554 304 stainless is a welded mechanical tubing used primarily for ornamental purposes. It is not fully annealed and is work-hardened slightly in manufacturing. It has good column strength and good bendability. ASTM A-269 304 stainless is a general service commercial specification that is higher quality and is fully annealed for better ductility. It is available in both welded seam and seamless, and is a good spec for the racer to use. We have not seen any difference in longevity between welded seam and seamless stainless tubing in header use, but there is a substantial cost difference. The column strength is not as good as A-554, but it has excellent bendability with a higher cost due to the full annealing.
MIL-T-8808/8606\MIL-T-6737 321 stainless are military specifications for aircraft tubing. Suffice it to say that some MIL-specs are not necessarily better or even as good as some ASTM standards. There is no particular magic here.
There are as many uses for stainless steel as there are projects in the shop. There is nothing else that transmits an image of quality and skill to the majority of fabricators than a cleanly constructed stainless steel project. Whether it is a set of headers, intake stacks, or even a stand for one's dyno engine cooling fan, stainless steel has such great mechanical properties that its use should be considered for many projects beyond exhaust systems.
From- http://www.popularhotrodding.com/tec...d_header_tech/
Burns Stainless recommends Inconel 625 alloy for exhaust systems due to its excellent strength, corrosion resistance and fabricability. This alloy also exhibits high creep and rupture strength; outstanding fatigue and thermal-fatigue strength; as well as excellent weldability (though the guy welding it might have a different opinion!). Inconel 625 contains molybdenum and columbium, which stiffens and strengthens the nickel-chromium matrix without precipitation hardening treatments. Some hardening however does occur when heated to intermediate temperatures (1200 F to 1600 F) increasing room temperature strength. Also, this alloy retains over 75% of its room temperature strength at 1200 F. This alloy is available in a wide variety of forms including tubing, sheet, bar, plates and castings. Burns Stainless typically stocks welded and drawn Inconel 625 tubing. The tubing specification is SAE AMS 5581, Nickel Alloy, Corrosion and Heat Resistant, Seamless or Welded Tubing.
From-http://www.burnsstainless.com/TechArticles/Inconel_article/inconel_article.html
Click top link for spreadsheet comparison on the details of the metals, basically inconel pwns and is highly expensive. Second link is from burns.
If F1 uses it, it is the best, or a signifigant amount of money has changed hands to make sure it's used, either way its highly over engineered.
Scorke
Scorke
Titanium dosent get hot, which kills exhaust velocity, which would make it pointless for downpipes and especially manifolds, Inconel, on the other hand, would be perfect. But pricy as hell.
