Turbo is maxed out, why?
Old Mar 12, 2007 | 03:29 PM
4WS Tuning's Avatar
For some reason i cant boost less than 30 pounds.
i replaced all my vac lines double checked everything. im not leaking anywhere...
i had the mbc/ebc set at 20 pounds and it wont run that. even when i turned both down to the minimum to run wastegate i cant.
when i connect the turbo outlet to the wastegate outlet i run wastegate boost
any ideas?
thanks!
here's another thread i made with a little more detail...
https://www.evolutionm.net/forums/sh...d.php?t=257039
Old Mar 12, 2007 | 03:32 PM
broddey's Avatar
Hey Tamer, what are your settings on the EBC?
Old Mar 12, 2007 | 03:35 PM
broddey's Avatar
Just a guess but could your boost gauge be off? 30 pounds is a $hitload for that turbo. . .
Old Mar 12, 2007 | 03:59 PM
4WS Tuning's Avatar
i have it turned down all the way....
and i tested it with a mbc turned down all the way... still does it...
Old Mar 12, 2007 | 04:00 PM
4WS Tuning's Avatar
thats also according to my boost gauge, the ebc boost gauge and im hitting crazy load while logging....
Old Mar 12, 2007 | 04:06 PM
DJ Brett B's Avatar
is your boost guage reading boost independently from the EBC?
Old Mar 12, 2007 | 04:07 PM
4WS Tuning's Avatar
ya...
Old Mar 12, 2007 | 04:08 PM
riceball777's Avatar
so your saying even you you dont run a boost controler and connect the boost source straight to the wastegate it still boost 30psi????
then your waste gate is broken cuz if you run straight off the stock waste gate it should boost 11psi.
you better be careful and get it fix before you blow your motor
Old Mar 12, 2007 | 04:09 PM
4WS Tuning's Avatar
but even if my boost gauge was completely off... when i have the mbc or ebc turned down all the way it should run wastegate boost... and its not...
cfdfireman1's Avatar
See if your wastegate is opening correctly pump some air into the line. Do this with the car off and look.
4WS Tuning's Avatar
naa when i look the turbo and wastegate it runs 11.... thats the frustrating part....
Old Mar 12, 2007 | 04:10 PM
sparky's Avatar
[quote=4 Wheel Slide;4079455]For some reason i cant boost less than 30 pounds. ......when i connect the turbo outlet to the wastegate outlet i run wastegate boost.
So, how many pounds per square inch is wastegate boost exactly, in your particular case? As I understand it when you connect directly from the WG solenoid to the compressor nipple you get base WG pressure. So how many PSI are you seeing?
Old Mar 12, 2007 | 04:22 PM
sparky's Avatar
So, when you connect directly from the WG solenoid nipple to the Compressor outlet nipple you get 11#. Now, with it hooked up in the aforementioned fashion and doing a WOT run in 5th, do you get boost creep or does it hold steady at 11#?
Old Mar 12, 2007 | 04:36 PM
4WS Tuning's Avatar
when i have it looped it holds 11 all the way to redline... no creep, no spikes
when i have the mbc plugged up it spikes 30 holds it til 5500 then tapers to 24 by 7500...
(i turned the meth on for this experiment and backed off the timing....)
Old Mar 12, 2007 | 04:55 PM
sparky's Avatar
So why not eliminate the EBC & MBC from the equation for the time being? That is, disconnect your controller and instead, set your flapper valve to open at your desired max boost level(18# or whatever) by adjusting the actuator rod(shortening it) a single 360* turn at a time until you reach 18# of preload. I know this seems Neolithic, but it'll hold boost steady at a much safer level than the 30# spike you are currently experiencing.
Just try this for the time being, that is, until you find out what the true source of your problem is. It is important for you to set preload at a higher than base(11#)level anyway. Sometimes when you are using a boost controller but your WG puck has no preload, the controller can't really control boost properly because the lack of preload causes the flapper valve to be constantly cycled on and off of its seat.
