IC fill bottle and Clutch question
Old Jun 4, 2003 | 04:04 PM
clappton's Avatar
Question IC fill bottle and Clutch question
Does anyone else have problems when they fill the IC sprayer bottle. Mine isn't even topped off, yet fluid comes dribbling out of the bottom. Is this common? Secondly, I have a little clutch whine when I first engage it after a long sit, i.e. the next morning. It only happens once a day, but wanted to know if anyone out there had a similar experience.
Old Jun 4, 2003 | 04:17 PM
AutoXer's Avatar
Notice the overflow tube on the fill bottle? You can't fill it to the top, which I find annoying.
Old Jun 22, 2003 | 06:15 PM
ShangaiSilver's Avatar
yup, there is an over flow tube. i filled mine, got freaked when it leaked out, called the dealer and they said it was the overflow.
i am not the sharpest knife in the drawer.
Old Jun 22, 2003 | 06:30 PM
silvrevo's Avatar
Ya but the thing that really sucks is that you cant tell the water is low in the tank. Does a light come on when we are low , or do we just have to keep adding water now and then? Or do we just let the pump burn out when it is empty and we still stry to squirt it?
Old Jun 22, 2003 | 07:31 PM
jedinite's Avatar
No light. Just keep checking it.
Pump makes a noticably different noise when its empty.
One of these days I'm going to plug up the overflow tube to up the capacity.
Old Jun 25, 2003 | 05:47 AM
Secret Chimp's Avatar
If you do plug up the drain tube, just make sure you drill a hole in the filler cap....or keep the cap cracked open a little.
Because the drain tube not only lets the overflowed liquid escape, it also lets air into the bottle as the water is used up. You wouldn't want to go creating pressure in the IC bottle, which would strain/reduce effectiveness of the lil water pump, ri?
SC~
neonglh
Sep 3, 2021 10:29 PM
gearheadvr4
Lancer Tranny/Drivetrain Tech
Apr 26, 2015 09:24 PM
Subi.convert
North Texas Evo Club (NTEC)
Jan 16, 2012 08:58 PM
billyblonco
14
Mar 17, 2009 09:35 AM
