Will the Forge bov hold boost on a GT35R?
Old Mar 16, 2007 | 08:52 AM
vmsturbo's Avatar
I am curious if i have to change my Forge bov to something stronger like the Tial bov when i get my GT35r? Right now i used the Forge because its recirculating and i am on stock maf. But if i later change to stand alone and take out the maf, will the Forge still be good enough?
Old Mar 16, 2007 | 08:54 AM
bvdawg13's Avatar
it depends wat kinda boost your gonna be running, but im gonna say yes it'll be fine, it can atleast hold 30psi from wat ive seen....if you go to stand alone then get the tial, the tial is definately a stronger bov and can boost higher
Old Mar 16, 2007 | 08:56 AM
kimletrim's Avatar
Registered User
Whether or not ANY boost controller is up to the task will depend on how much boost you plan on running and the type of wastegate you will use. Basically, most MBC will work the same way so it really shouldn't matter which brand you choose. The Forge is a very nice unit. Depending on your wastegate pressure, you can boost well over 30 psi with the FOrge.
Old Mar 16, 2007 | 10:12 AM
vmsturbo's Avatar
yea i'm definately hoping i can keep my forge unit as it is a quality unit. As for boost, i don't think i'll see anything over 30 psi.
Old Mar 16, 2007 | 02:04 PM
A418t81's Avatar
I have a forge diverter valve on my stock ECU/maf 35R evo and it works very, very well.
