Boost Pressure??
Old Mar 16, 2007 | 05:10 PM
nick_622's Avatar
Boost Pressure??
Hey Guys,
I recently switched from an Autometer Mechanical Boost Gauge to a Prosport Electronic Boost Gauge, and my boost pressure is now reading about 5-6 PSI lower. My boost should be set to 21PSI per my tune from Al of Dynoflash.
Is their a test of some sort to find out how much boost I'm actually running??
Also ... what is the size of the Hotside on a stock 2005 Evo VIII?? Is it the same as the 10.5 Hotside on the MR's??
Thanks,
Nick
Old Mar 17, 2007 | 11:09 AM
nick_622's Avatar
bump
Old Mar 17, 2007 | 12:28 PM
TVA's Avatar
TVA
Originally Posted by nick_622
Hey Guys,
Check for boost leaks at the sender for the electric gauge and anywhere else in the system
Did you remove any restrictor pills from the stock boost hoses? Are you still running the stock boost control system?
Short of a MAP sensor with a display ala Zeitronix a gauge is really the best you've got.
Yes
Old Mar 17, 2007 | 12:30 PM
chaotichoax's Avatar
the standard viii 10.5 hotside is a dual flapper design I believe while the mr is a single flapper but either way size wise they are the same
franc01
Jun 16, 2015 11:24 AM
jhanksevo
19
Oct 13, 2008 04:31 PM
Blue Evo 8
13
Mar 8, 2006 03:55 PM
talon2evo
Mar 2, 2006 08:45 PM
nickracer9
24
Feb 20, 2005 07:18 PM
