Which blow off valve?
for the newb OG poster: venting to atmosphere is stupid. no cool sound is worth the negative effects of doing this. you only really need one if your stock one isn't holding boost.
I suggest you start reading about the differences between atmospheric BOV's and By-pass valves. It's not worth it buying an atmospheric BOV and the whoosh sound was only a fad. I wouldn't buy one.
I don't understand why some people waste their time to type when they can just use the x out option (right hand corner of your window). Anyways I left mine stock good luck with your search hope you find the answer you're looking for.
A cone filter is simply a filter shaped like a cone, nothing special like that; opposed to a drop-in filter like a K&N or the Works that simply replace the stock filter.
BOV: Stock Evo IX is fine until you start running anything past 23 psi, Forge RS or TiAL if and when you go for higher boost levels.
I would go TiAL though, but you need to be running MAF'less, so the Forge would be a good way to start.
C'mon guys don't flame the new guy; the search function is not the greatest.
BTW, this should be in the newbie section.
