12.00 in the AMS EVO8
Old Jun 5, 2003 | 01:06 PM
AMS's Avatar
AMS
We finished a cam test yesterday and where so pumped we threw the car together and took it to the track last night. The car made about 350whp and 330ft-lbs of torque on the dyno so I knew that an 11 was possible it the stock clutch held up. We drove to Great Lakes Dragway and the first pass netted a 12.00 at 113.89mph. Every run after that was in the 12.1 range since the clutch was slipping pretty badly at the launch. After about 3 runs I noticed that we had a pretty good boost leak! I installed some fittings on each intercooler endtank to test pressure drops and I had then capped the fitting off with vacuum caps. When we installed the front bumper the mesh interferred with the vacuum cap and sheared it off leaving a nice 1/8" opening Bummer, I'm guessing that probably cost us about 10hp and 1mph in the 1/4. Adam Dubienczuk drove the car and he also did not spray the IC like I did the last time I took the car down the track. I noticed about a 1mph increase when I did spray the IC the whole way down so that might have hurt us also this time around. Giving the boost leak and not spraying the IC I think we could have pulled a 115mph trap speed out of it. Soooo close to 11's
We developed a twin disc clutch for the DSM's and now we're adapting it to the EVO8 so we should have it in the car next week and we'll return to the strip for that elusive 11 sec pass.
Mods to the car:
AMS stage II mods- consisting of: (a clutch will become part of our stage II kit)
AMS EVO8 downpipe-& cat-back
K&N air filter
AMS manual boost controller
AMS MAF pipe
Apexi-S-AFC
HKS 272/272 cams
Lightweight battery (10.5lbs compared to stock 35lbs battery)
here is a link to the video of the run at Great Lakes Dragway
www.automotosports.com/media/evo_viii_1200.wmv
-Martin
Old Jun 5, 2003 | 01:09 PM
PRVRT's Avatar
Great Video!!!!! Nice run also!!! Kepp us posted on the progress of your project!!!!
Old Jun 5, 2003 | 01:11 PM
Guru_Del's Avatar
man nice run couldn't break in the 11's thou eh? hahah j/k you will get it next time. Keep up the good work!!!!
Old Jun 5, 2003 | 01:12 PM
BadBoyBeltran's Avatar
Martin,
You think the HKS cams and an MBC will be enough for now to smoke the STIs? How many HP you think this will generate? Are any additional mods really essential?
Thx. STI
Old Jun 5, 2003 | 01:15 PM
Whats the difference between the JDM and US Evo's aside from the 6MT, AYC, ACD?, I mean as far as emission and smog stuff that can be changed to make our cars faster....
Old Jun 5, 2003 | 01:16 PM
I also think 11s are easy w/o the clutch slipping. Cool video!
Old Jun 5, 2003 | 07:55 PM
Incognito's Avatar
Wow, congratulations.
Did you guys dyno your car before/after the HKS cams?
113.89mph, I'm impressed
Old Jun 5, 2003 | 08:15 PM
RENN-ART's Avatar
hell yeah!! i heard about this yesterday, and i was and almost posted asking where the video was!!
cant wait to get it all on my baby!
btw, i need that clutch too!! mine is pretty much fried and it's really difficult to launch it without completely dropping the clutch..
list of short-term planned mods:
1.) ur awesome 3" turboback (by wednesday right!? )
2.) clutch
3.) hks 272/272 cams
4.) dyno tuning
5.)
Old Jun 5, 2003 | 08:59 PM
Speedlimit's Avatar
Admin Emeritus
Nice run fellas..... and the verbal comment on the video at the end expressed your dispappointment! You guys are going to have to start worrying about getting "kicked" by technical without a roll bar! Love it!!
Speedlimit...
Old Jun 5, 2003 | 10:14 PM
jfh's Avatar
jfh
Very impressive run. What kind of cam timing adjustments are you using with the 272/272 cams?
How did they impact overall power curve? Must have been some low-mid range trade-off to get the peak numbers up.
Old Jun 5, 2003 | 11:34 PM
Alfriedesq's Avatar
Nice run - looks like those cams work well on the part of the power band that we use while drag racing - 5,000 - 7,000 - and they make at least 30 hp on top - - - I'm curious to see a dyno sheet to see how the 3,000 - 5,000 rpm range is effected - if at all by the cams
Old Jun 5, 2003 | 11:41 PM
insomniac_evo's Avatar
sweet numbers
Old Jun 6, 2003 | 12:04 AM
bobaab's Avatar
wow..12 flat..what a teaser lol. good luck to u guys!
Old Jun 6, 2003 | 12:17 AM
jedinite's Avatar
Awesome news. Great work guys, keep us updated. I have faith that you guys will be the first Evo in the US in the 11's...
Old Jun 6, 2003 | 12:19 AM
fuzzypunks's Avatar
Were you guys running pump gas or race gas at the track and on the dyno?
