Boost spikes like crazy all of a sudden
Old Mar 22, 2007 | 01:24 AM
Nerologic's Avatar
Just a hair over 36k.
I have had the same mods for the last 5000 miles. But all of a sudden boost spikes all the time.
Usually i would have to set the AVCR at 1.45 to hold 1.45 bar of boost, but now when its at .6 bar it spikes up to 1.6 at times like if the boost controller was set at 1.5.
Mods are just o2 housing turbo back test pipe intake manifold and a boost controlled 3 inch dump on the downpipe.
Nothing has changed, so im not sure what it can be...
Old Mar 22, 2007 | 01:39 PM
Nerologic's Avatar
up for anyone that knows...
Old Mar 22, 2007 | 01:56 PM
DynoFlash's Avatar
check all the hoses from avcr to the car to make sure there is not a problem in the hose going to the wastegate
if that fails - reinitzlize the avcr
Old Mar 22, 2007 | 11:59 PM
Nerologic's Avatar
il check tomarow, i really havent had a chance to check...
could a leak be causing this??
Old Mar 23, 2007 | 12:03 AM
4WS Tuning's Avatar
sounds like a leak in the vac hoses...
my friend's vac line rubbed the fan and developed a hole and was spike crazy...
cheers!
Old Mar 23, 2007 | 06:57 AM
NoTec's Avatar
Definately sounds like a leak in vac hoses. Did you secure the hoses during initial install?
Old Mar 23, 2007 | 07:06 AM
mifesto's Avatar
yes last time this happened to me the hose from my MBC to the wastegate was almost falling off
Old Mar 25, 2007 | 04:39 PM
Nerologic's Avatar
well i figured out the problem....
the actual AVCR vallve is bad...
time to buy a new one :
