tech discussion: what keeps torque from dropping off?
Old Mar 22, 2007 | 12:39 PM
trinydex's Avatar
torque can be loosely associated as a product of exhaust gas velocity. horsepower can be loosely associated as a product of mass flow. an example to clarify is that big horsepower cars flow a lot of air and what we view as torquey cars generally make thier torque low when the volume flow has high velocity. now i say loosely associated because gearing has to do with both factors and also because of what i'll explain next.
high horsepower engines with enough compensative gearing make high amounts of torque, however we do not view these cars as torquey but peaky. take for example an f1 2.4 liter v8. it'd be hard to convince me that this motor doesn't make a ton of torque at 16k rpms... but that's the problem isn't it... 16k rpms makes your car sound like... well an f1 car. so snap back to the real world for a second.
a typically torquey motor is the lsX motor where X can be 1, 2, 6, 7 etc... basically the vette/fbody motor. this motor generally displaces more than 6 liters so it flows a ton of air. but generally it flows at lower cylinder pressures than a turbo car like the evo. now with that basic qualification out of the way it doesn't matter.... now i say this because if you flow 1 pound through a 2 inch^2 hole... the hole loosely dictates the speed of the gas. that said the lsx's optimum flow is TYPICALLY at the midrange which gives you that low end torque feel.
now why did i say optimum flow? well because the cross section of the pipes going in and pipes going out of the cylinder dictate the flow speed and hence the torque (loosely again). so when you achieve optimum flow you achieve some level of peak torque (this can be modified). so if you made all the ports REAL big in the lsx would it then become peaky? absolutely. this is what's known as shifting the powerband or torqueband around.
see in the end this is a limitation of engineering, you're asking to maximize two fundamentally opposing quantities. here's the punch line. small flow area increases velocity but limits maximum flow potential, large flow area decreases flow velocity but increases maximum flow potential. NOW this is relative... what i MEANT to say was small flow area increases LOW END gas velocity but limits HIGH END maximum flow (tha last two adjectives were redundant) and large flow area decreass LOW END flow velocity but increases HIGH END FLOW VELOCITY which produces a HIGH END TORQUE!!! a bigger hole is idealized to a bigger flow.
if you had a 2" hole and it produced 100 foot/second flow speed at 4000rpm then a 3" might do the same at 6000rpm.
this is why in drag racing it's always better to shift the rpm higher, because you're never going to lose torque unless you can't gear yourself into the powerband.
if you cut yourself short by getting low end torque, you're LOSING HIGH END TORQUE!!!
now to answer your question of what gets you to keep the torque from dropping off. well the answer to any limitation of engineering problem is likely variable geometry of some sort. you can have a variable geometry turbocharger, this allows you to flow fast at the low end and fast at the high end... this creates a nice torque band that is relatively flat the whole way through, never dropping off while your hp increases the whole time. the other way is variable valve timing, you can change the flow characteristics/speed of the engine by changing the valve timing (mivec).
ball bearings and various sizings of turbos would only change what they call "static" quantities. in order to get the best of both worlds you need dynamic quantities.
Old Mar 22, 2007 | 12:40 PM
trinydex's Avatar
continued
Originally Posted by BHCevo
I agree with everything trinyDex says. His stated correlations between exhaust gas velocity, mass flow, torque and horsepower more or less capture what happens in the real world and correctly highlight compromises needed between optimzing peak torque or optimizing peak horsepower.
That being said, I'll offer an equivalent but alternate explanation that better highlights the fundamental relationship between torque and horsepower.
First, I want you to think of your engine as something that makes torque. Forget about horsepower, think torque. Torque is force multiplied by a lever arm. In this case, force is the force supplied by the power stroke and lever arm is the geometry of the crank/rod/piston. In this case force is actually the time averaged force over all the power strokes of all the cylinders.
Okay, two things conecern us here
1) How do we increase torque? Well, most of the time we increase the power stroke force. The time averaged force goes up as
the total amount of fuel and oxygen we burn in all our cylinders increases. In general, we can inject arbitrary fuel (yeah EFI), so we are really limited by the amount of oxygen we can stuff into the cylinders. There are two ways we increase the total mass oxygen we burn
a) Increase combustion volume (displacement)
b) Increase combustion oxygen pressure (forced induction ie turbos or superchargers)
Or both hehe.
2) The other thing that concerns us is ...why does the torque output vary with engine speed? Generally speaking.
Simple. Torque is the product of (oxygen mass being burnt) times lever arm. Your lever arm isn't changing so clearly the oxygen mass being burnt is changing. as a function of engine speed. Your displacement isn't changing, so your combustion oxygen pressure MUST be changing, regardless of the presence of forced induction.
Why does the combustion chamber oxygen partial pressure change as a function of engine speed? This is because in the real world the fluid mechanics of gas (oxygen) flow matter greatly for establishing the actual amount of oxygen that got into the cylinders during the brief time the intake valves were open. Look at your torque curve....it is actually the curve of the efficiency with which your cylinders fill with air, as a function of engine speed. This is also called volumetric efficiency.
Volumetric efficiency depends greatly on intake geometry, exhaust geometry, intake and exhuast PORT geometry, intake manifold geometry and exhuast manifold geometry. It also depends on cam shaft timing and valve timing (hence will change with MIVEC or different cam shafts or cam gear settings).
How volumetric efficiency varies with port geometry is what Triny was saying above. In his language, a "torquey engine" means an engine with the torque (volumetric efficiency) peak at low engine speeds. Because the torque peak occurs at low engine speeds, there is no point in a high redline, so you better have big displacement to give you torque at the crank since you cant depend on short gears to give you that torque boost at the wheels.
A "high horsepower engine" means an engine with a torque peak (volumetric efficiency peak) ocurring at high(er) engine speeds. Thus you can get away with smaller displacement, and a small value of the peak torque, because you can use short gears to boost your smaller crank torque. You can use shorter gears because your useful redline is higher. Why a high engine speed torque peak is called high horsepower i'll explain below.
I'll summarize the important point one more time: to increase HORSEPOWER you sacrifice your peak torque height (at midrange) in order to improve your redline torque. Your peak hasn't moved to redline, although it has moved up some, but your torque near redline is better. Why does this increase horsepower? I will explain below.
Okay, torque torque torque. What about horsepower. Here ya go.
Horsepower is torque times engine speed. Thats it. Thats all you need to know. HP = Torque X RPMS.
From this simple fact follows many things:
1) Peak Horsepower occurs closer to redline than peak torque because as engine speed goes up horsepower goes up proportionally, independent of torque. Hence, in order to optimize horsepower usually you sacrifice your midrange torque peak in order to bolster your near redline torque. It usually turns out that Peak Torque X 4000 RPMS < Redline Torque X 7000 RPMS. You can think about this.
3) A high horsepower engine, everything else being equal, has a higher redline. The max engine speed is high.
2) A high horsepower engine, everything else being equal, pulls hard because you can get away with SHORTER GEARING at HIGHER SPEEDS. Thats it. Thats why a high horsepower engine provides good acceleration. No other good reason.
3) A high horsepower engine with tall gears is slow(er).
5) Maximum velocity goes up with horsepower (not torque), everything else being equal. Of course, it might take you forever to get there because your torque (acceleration) sucks but...
By the way, I'm assuming you understand how your gear ratios act as a torque multiplier at the wheels.
My last point is: what makes a car pull hard is torque. Thats it. The only reason high horsepower makes your car pull hard is because it lets you stay in lower gear for a longer time (low gears provide more torque at the wheels). Thats it. EVERTHING ELSE BEING EQUAL.
I realized I never really answered the OP question. Here ya go.
To keep torque from dropping off you need (infinitely) variable intake/exhaust valve timing/lift (go BMW!) and also variable intake/exhaust geometries (go Porsche!!). In both cases I believe the intake valve timing and intake physical geometries are more important than the exhaust sides. I might be wrong about the relative importance of the exhaust and intake sides. Hafta think about it.
In practice, if you want higher torque at redline just raise the boost (go C-16 fuel!!). You will still have a peaky torque curve but at least the whole curve will have increased by a constant factor and you will have better acceleration (torque) at redline. Of course, now your midrange torque might be a little
much...hehehe
Triny mentions variable geometry turbos (VATN turbos). These turbos have all the good characteristics of a small turbo (super fast spool, low end torque) and a large turbo (high end torque, flow huge CFM). Crazy, eh? Theoretically, a perfect VATN turbo needs no wastegate and no boost controller since you can control maximum boost by varying your turbo geometry in real time. Sounds too good to be true? Well, the newest carrera turbo utilizes twin VATN turbos. I believe truck turbos have utilized VATN for a while now. Of course, the benefits of VATN are only realized to the extent you can vary the turbo geometry. Big variations mean big benefits, small variability means small benefits.
VATN turbos eliminate the peakiness associated with the turbo sizing. However, you still have the volumetric efficiency variances associated with static valve timing and static intake/exhaust geometries. so you'll needs VVT on top of VATN to further flatten the torque curve.
Old Mar 22, 2007 | 02:27 PM
Ted B's Avatar
Originally Posted by trinydex
torque can be loosely associated as a product of exhaust gas velocity. . . . take for example an f1 2.4 liter v8. it'd be hard to convince me that this motor doesn't make a ton of torque at 16k rpms... so if you made all the ports REAL big in the lsx would it then become peaky? absolutely. . . . this is why in drag racing it's always better to shift the rpm higher, because you're never going to lose torque unless you can't gear yourself into the powerband.
- Torque can loosely be associated as a product of dynamic cylinder pressure, not necessarily exhaust gas velocity.
- An F1 2.4L V8 does not make a great deal of torque . . . anywhere in the rpm range. What little torque it does make is focused high enough in the rpm range to generate a great deal of hp.
- If one made the ports 'real big', it would tend to favor shifting VE higher in the rpm range, but that also depends upon other factors.
- In drag racing, all else being equal, the driver that gets the most average hp into each gear interval is always faster. This being the case, torque doesn't matter aside from the fact that hp = tq with respect to rpm.
Old Mar 22, 2007 | 04:02 PM
trinydex's Avatar
just wondering, when does exhaust gas velocity not depend on cylinder pressure? i can see at least one extreme instance where you have tons of cylinder pressure and no torque.
it gets muddy when we talk about the sublte difference between the instantaneous force and the work produced... which also has to do with gearing.
anyway, let's all talk more about it.
Old Mar 22, 2007 | 04:21 PM
mudduck's Avatar
I'm having difficulty comprehending why torque is not as important as high horsepower in drag racing, when as BHCevo stated above, "torque is what makes the car pull hard," and acceleration = torque.
Slightly off topic question #1: Is anyone working on a variable geometry turbo (aka 997 Turbo - full boost at like 1950rpm + good top end) for use in our Evo's?
Question #2: Does anyone run two different turbos (i.e. a small, quick-spooling turbo like a 16g + a GT35r) in a twin turbo setup?
Old Mar 22, 2007 | 04:22 PM
Ted B's Avatar
This will occur when the ignitional timing is such that the fuel charge burns very late in the combustion cycle. Exhaust gas velocity is increased as a result of sharply increased heat, but this isn't increasing pressure on the piston at a relevant part of the combustion cycle, and therefore torque actually suffers.
Torque is not a function of exhaust gas velocity.
Old Mar 22, 2007 | 04:25 PM
RoadSpike's Avatar
But shouldn't the gases expansion rate play a factor to the amount of torque generated?
Take in account that dyno's measure torque as a function of time.
top: torque = change in momentum / change in time
middles: momentum = Interia * angular velocity
bottom: Kenetic Energy = Inertia * angular velocity ^ 2
My understanding isn't fully complete so here's what I believe the problem lies in.
If we base our understanding on the most simple case like an electric motor where VE and everything is completely negligible. We can assume a motor of some size can output X number KW of power. If the engine is merely adding kentic energy then the exponential increase in kinetic energy at higher rpm could easily explain why making torque at lower rpm.
Torque of a simple electric motor:
Old Mar 22, 2007 | 04:27 PM
Ted B's Avatar
This is because torque is a static measure of force, while HP is a measure of how quickly that force is being applied with respect to time. This is why a diesel truck can pull a tremendous load, but accelerates slowly.
Make two drag strip passes, (1) shifted such that hp is maxmized in each gear, then (2) such that torque is maximized in each gear. (1) will be MUCH faster each time.
Old Mar 22, 2007 | 04:30 PM
Ted B's Avatar
Not when said rate of expansion is taking place while the piston is too far down in its stroke. The result is hot (fast) exhaust gas, but not improved torque.
Old Mar 22, 2007 | 04:33 PM
RoadSpike's Avatar
Ah that makes sense to the rate of expansion is relative to cylinder pressure and its speed but not directly correlated.
Old Mar 22, 2007 | 04:45 PM
mudduck's Avatar
OK, but if in a roll-on race (closed course...) from say 3rd gear, do you try to start the roll-on at your peak torque or closer to your peak whp?
Old Mar 22, 2007 | 04:52 PM
Ted B's Avatar
It isn't so much about where the start is, as it is the average power between the start AND finish of any given gear.
Old Mar 22, 2007 | 04:56 PM
mudduck's Avatar
^^^ by average power I'm assuming you're referring to whp... so your torque peak is not as important in this case? (other than indirectly contributing to hp given the original posted equation...)
Old Mar 22, 2007 | 05:24 PM
Ted B's Avatar
whp would be the most pertinent expression in this case. Or to be more precise, averange whp.
Old Mar 22, 2007 | 06:44 PM
trinydex's Avatar
the short answer is that horsepower is higher rpm torque. two cars that both make the same torque, the one with hte higher revlimit will hit higher horsepower. in drag racing this only makes tons of good sense.
