what does you boost taper to?
I run 26psi on alky, and it tapers to 16psi by 7500rpm. I am curious why he's asking - he gave no details. Is that ok with you? Now, show us a MAP sensor log of your boost holding a flat line at 22.7psi for over 4000rpm.
And let's be real--you asked for details so that when he says something that every idiot noob should know about evos you can berate him thereby showing how much more "advanced" you are. I can probably track down a number of your posts wherein you do this exact thing.
But before you go any further king ding-a-ling; don't bother replying. Let's not hijack the thread with a side conversation. Thanks....
Thanks for the answers,I was just asking because lately it seemed the boost has been droping alot more then usual at higher rpm's.just recently my wastgate actuator broke.so i put the stock one back on on for now.(i have a white rabbit turbo with force performance actuator).and my halmon boost controler also broke to so i got the turboxs and you told me it pretty much sucks.(warrtalon)so i was just trying to troubleshoot the problem.the boost goes to about 24 pounds and fades down to 18 19 at around 7,000.thanks for the hep.
Go for the Forge WGA. It is a nice, quality piece. Did you mention what DV/BOV you are running? On here they recommend either the Forge Unos or the Hallman MBC. I have had good reults with the "El Cheapo" DejonTool MBC, so far.
