50 trim on stock manifold ?
Old Mar 28, 2007 | 10:12 AM
sabastian458's Avatar
Originally Posted by shawnevo69
Cant u use the atp turbo kits? they bolt up to stock manifolds and go from 50 trims to 35r's
look at a dyno graph of an atp kit. you wont like it. green is the way to go
Old Mar 28, 2007 | 10:42 AM
Ted B's Avatar
Originally Posted by speedfreak0920
i'm looking at 1000 TOPS.
A word of advice . . .
Keep saving.
Old Mar 28, 2007 | 10:43 AM
WaxThis2005's Avatar
Originally Posted by TVA
Here is a post of a guy using the Evogreen on pump with 21lbs of boost. Obviously a Dynojet.
Now here is a guy using an AMS 50 trim similar supporting mods minus the AEM EMS on 93 octane and 22 lbs of boost. Also a Dynojet.
Thats funny, Thats my car on the AMS dyno sheet. If you look closely you will see that both turbos have same spool up time. I love my AMS kit. I was in the same bind trying to pick the right turbo for me! I am extremely happy with the AMS 50 trim kit! And it will have much more to give up top escpecially if you put race gas in the car!
Old Mar 28, 2007 | 10:46 AM
Vigo's Avatar
FP Green for the win.
Old Mar 28, 2007 | 10:49 AM
You guys have to look at the temps in the dyno room also, It was 20 degrees warmer for my 50 trim run. And the 20 glt guy has to have a race engine if he is spinning to 8300 rpms? That also make a big difference. I love my turbo upgrade! But if you are only looking to spen 1000 dollars dont expect a complete kit. AMS came with everying, such as intake, downpipe, header, lower intercooler pipe.
Old Mar 28, 2007 | 11:27 AM
trinydex's Avatar
hey finally a thread with a firm evogreen 50trim comparo
Attached Thumbnails 50 trim on stock manifold ?-2psf575.jpg   50 trim on stock manifold ?-43mweud.jpg
Old Mar 28, 2007 | 11:36 AM
Vigo's Avatar
Those graphs should be stickied.
Old Mar 28, 2007 | 12:16 PM
sonicnofadz's Avatar
You can get a gt35R, GT3071R, or GT3037S fitted with a turbine housing that bolts to the stock Evo manifold here: (about $1250 per turbo)
http://www.himni-racing.com/index.ph...x&cPath=66_134
Old Mar 28, 2007 | 12:20 PM
deadbeatrec's Avatar
i have the ATP kit with the 3037s and made 400whp on 93 octane and 21 psi.
Old Mar 28, 2007 | 01:01 PM
Sean03Evo8's Avatar
it should work my friend with the talon awd(4g63) has the 50 trim to the stock manifold
Old Mar 28, 2007 | 02:00 PM
Creamo3's Avatar
Correction factors on those two graphs are different as well: (Uncorrected/Turbo Trix) (SAE AMS).
Old Mar 29, 2007 | 10:33 AM
speedfreak0920's Avatar
sonicnofad: thnx man for that link. i'm def. going to look into that.
i would love to get a COMPLETE kit but I don't have the funds right now. that's why i'm trying to figure out a good turbo to fit my stock mani (ported n coated). what kind of mods will i need to support that fp green ? i may just have to save up and go with that. i'd end up spending the money on suspension or something else if i tried saving 3g's for a complete 50 trim kit from say, ams or buscher.
thnx
silva
Old Mar 29, 2007 | 10:36 AM
edit: How does the 6.5 turbo with the 10.5 hs perform? at what power level does the turbo max out? that's only 900 ? thnx again
Old Mar 29, 2007 | 10:44 AM
Links0000's Avatar
hmmm I like these
Old Mar 29, 2007 | 11:54 AM
mudduck's Avatar
The FP Green costs $999 + $300 core charge via the exchange program.
When you give them your VIII turbo, you will be credited back the $300.
If you give them back a IX turbo, you get back $450.
