oil cooler setups
Old Dec 28, 2008 | 12:04 PM
  #46
E7R's Avatar
E7R
Originally Posted by joedr
Can't I just use the trigger from the radiator fan and avoid the use of another thermoswitch?
You can also use the Tomei oil thermostat removal and re-use the OEM lines.
Any thoughts or comments?
The cost of this circuit is less than 200$ and its really working well.
Old Dec 28, 2008 | 12:13 PM
  #47
nothere's Avatar
you can do a lot of damage from having your oil to cool, that is why a proper thermostat is important.
Old Dec 28, 2008 | 12:16 PM
  #48
turboandbroke's Avatar
i havent read the whole thread but in our race nsx we had pwr make us a radiator with a built in oil cooller .... has anyone done that on there evo?
Old Dec 28, 2008 | 01:01 PM
  #49
joedr's Avatar
EvoM Moderator
where did you hook up the thermoswitch?
Old Dec 28, 2008 | 02:10 PM
  #50
E7R's Avatar
E7R
On the Oil Block Sensor Adapter
Old Dec 28, 2008 | 07:22 PM
  #51
Gumby56's Avatar
any body got ay picks of fluid to fluid installed
Old Dec 31, 2008 | 12:48 AM
  #52
3zero7's Avatar
which setup would be better?
1) replacing the factory 13rows oil cooler with a 25-30 rows oil cooler, single bigger oil cooler
2) keep the factory oil cooler, and add another oil cooler with the same size as factory, twin oil cooler
Old Dec 31, 2008 | 04:48 AM
  #53
EvolvedMR's Avatar
Great thread!.
I'd like to see more hard data. Such as what HP are you running and where are your temps. One person stated 260 on the track. After an oil cooler upgrade what are your new temps?
Does anyone have an idea of what the ideal temp range to shoot for should be? 200-230 deg?
I really want to do an upgrade, but I just added an oil temp gauge, and I want to see where I am at before I take the plunge. On the street, oil seems to run about ten deg higher than water temp. 180/190. I am adding a CBRD rad now. Curious to see if that has an effect on street temps. Probably not because any lower and I think the thermostat would come into play. No data to compare for track temps though.
Old Jan 1, 2009 | 03:00 PM
  #54
Fast-Mover's Avatar
I wander if one of those EBAY oil coolers would work just as well as some of the higher brands such as Greddy or HKS or AMS's new oil cooler system
Old Jan 4, 2009 | 05:47 AM
  #55
3zero7's Avatar
i was wondering also if a bigger oil cooler or a twin setup would affect the oil pump?
Old Jan 4, 2009 | 07:27 AM
  #56
joedr's Avatar
EvoM Moderator
Thumbs up
Just ordered this setup!
1)keep your OEM oil cooler
2)order new costum made (non restricted)oil lines(send & return)
3)order a SPAL electric fan :
+ its connection kit (Thermoswitch, Relay and Wiring Harness):
and u've done.MORE INFO HERE fans>>motorcycle/ATV>>5.2''
Old Jan 4, 2009 | 07:44 AM
  #57
Sharkbite2000's Avatar
Just got my AMS oil coiler it's off the hook very nice peice.
Old Jan 5, 2009 | 07:50 PM
  #58
joedr's Avatar
EvoM Moderator
I bought the puller fan and the thermo switch @ AbsoluteRadiator.com
Good pricing and fast delivery.... even to Puerto Rico. Worth to look!
Will post the installation pics and details as soon as I get the parts.
Old Jan 10, 2009 | 03:19 PM
  #59
skatermsmn's Avatar
Does anyone have any pics of there no cooler setup, I have heard alot of people dont run one, but I have not seen how its done. Do you just plug the system or run a line between.
Old Jan 11, 2009 | 12:47 AM
  #60
Gumby56's Avatar
two intercoolers one for oil one for air lol
