Which spark plug to replace with??
Old Mar 27, 2007 | 06:19 AM
SEEnoEVO's Avatar
I am going to be installing 272 cams next week, and plan on changing out the plugs while I am at it. I was wondering if I should change the heat range and what brands everyone recommends. My mods are(will be) as follows: Helix 272 cams, walbro, Apexi Intake, DC Sports Downpipe and Cat delete, Helix Exhaust, APS BOV, and custom flash by Jestr. Thanks for your input guys!!! This place ROCKS!
Old Mar 27, 2007 | 06:21 AM
rcheung's Avatar
You should be good with one heat range colder.
Old Mar 27, 2007 | 06:30 AM
BoostEEd's Avatar
NGK BPR8ES
You need to update your waiting to be installed list and who will be installing and how sexy he is
Old Mar 27, 2007 | 06:37 AM
Luis@TTP's Avatar
goe with the ngk bpr8es works great
Old Mar 27, 2007 | 06:39 AM
drano7823's Avatar
Im actually getting my cams install this weekend to and we have or will have similar mods and I was told to go with the BR8EIX from NGK
Old Mar 27, 2007 | 07:09 AM
EvoLutionized8's Avatar
really?? I have just about every bolt on mod too with FP Green turbo comin and it was recommended to use BPR7ES, as I have been from the beginning.. I'm not questioning why, but should I upgrade as well to the BPR8's?? thanks for any advice.. Mike
Old Mar 27, 2007 | 07:17 AM
BoostEEd's Avatar
I would think the only advantages would be that they will last longer and help make your wallet lighter. I figure I'd rather change $8 in plugs every other oil change than change $100 in plugs once a year or so.
Old Mar 27, 2007 | 07:24 AM
V8EaterEvo's Avatar
No, there is no benefit on going to a colder range of plugs. You are still on your stock turbo, so no need. It's just a waste of money. Spend your $$$ on something else.
Old Mar 27, 2007 | 07:41 AM
BoostEEd's Avatar
What is the reason for going to a "colder" plug in the first place?
Old Mar 27, 2007 | 07:57 AM
rcheung's Avatar
Colder plugs help prevent premature detonation. From what I understand when you have rougly 100 whp over stock you should use colder plugs.
Old Mar 27, 2007 | 08:08 AM
V8EaterEvo's Avatar
Not really. It has to do with boost and with the stock boost and stock turbo, you don't have to go to a colder plug. But yes, it does do what rcheung said.
Old Mar 27, 2007 | 08:29 AM
BoostEEd's Avatar
ok that kind of makes sense. I understand premature detination, but the spark is happening the same time with either plug so how does a colder plug prevent it prematurly detinating? Sounds like maybe its simmilar to turning timing back in that there is more delay in the spark with a colder plug? or more delay for the colder plug's spark to create detination?
Excuse my ignorance here.
Old Mar 27, 2007 | 09:10 AM
SteelEvo's Avatar
the colder plug removes more heat from the cylinder....thus taking away another component that can cause detonating..i have the br8es..it helps when running high boost...they just foul easier then the "BPR" 8/7 heat ranges and above
Old Mar 27, 2007 | 09:27 AM
BoostEEd's Avatar
OK that seems logical.
Old Mar 27, 2007 | 10:04 AM
vmrevo9's Avatar
Veteran: Air Force
so is the stock plug sparks recommended for a "stage 1 upgrade" with no meth or alky and running 23-24 psi on a stock turbo?
