why does my car do this....
Old Mar 28, 2007 | 06:45 PM
Joe03's Avatar
hey guys,
well i bought a 06 MR last friday, and every time i would wash the car and go drive afterwards, the idle jumps up to about 2500rpm when i hit the brakes. when im just holding the clutch in it idles normal, but as soon as i hit my brakes it jumps to 2500rpm and stays there until i let off the brakes. after driving around for a good bit it gradually goes down, until finally its normal. why does it do this? does anyone else have the same problem?
Old Mar 28, 2007 | 06:51 PM
smokedmustang's Avatar
Do you have a wooden leg, and by chance are stabbing the clutch instead of the brake? jk no clue. sounds odd.
Old Mar 28, 2007 | 06:54 PM
Blkhrt's Avatar
ummm......there is no way to know...hope this helps
Old Mar 28, 2007 | 06:56 PM
Evil8MR's Avatar
I agree! Very odd...
Sounds like you should get a second opinion.
Old Mar 28, 2007 | 07:02 PM
Joe03's Avatar
im only pressing the brake, not the brake and the gas like someone told me before. i know this because i pressed it with my hand...
is there anything under the hood that water might leak on that could cause this? like i said it ONLY happens after i wash my car, so water has to be getting on something or hitting something to cause this
Old Mar 28, 2007 | 10:54 PM
CasperGSR99's Avatar
my integra i used to have would climb in RPM if you pumped the brakes while idling.
possibly the same thing?
Old Mar 28, 2007 | 11:42 PM
Ride927's Avatar
not to go off topic but if u bought your car last friday how many time could you have washed it lol
and yah thats kinda wierd
Old Mar 29, 2007 | 04:23 AM
DanJ's Avatar
Does it really jump 2500? that's quiet a lot. I know if I'm cruising to a stop in neutral and stop quickly (or break traction) the abs system kicks on and my idles go up a little.
Old Mar 29, 2007 | 04:28 AM
electricevo's Avatar
could just be the brake booster requiring a higher RPM than idle to operate...I dont know why it only does it when the car is washed though?
Old Mar 29, 2007 | 04:44 AM
Import Junky's Avatar
he coud have washed it everyday
Old Mar 29, 2007 | 07:47 AM
skoarpio's Avatar
take it mitsu
Old Mar 29, 2007 | 07:52 AM
nofear's Avatar
I agree...take it back to the dealership and have them check it out.
I have a IX MR and have never had that problem....even after the car gets a wash.
Old Mar 29, 2007 | 08:44 AM
mudduck's Avatar
Damn, you beat me to it!
Old Mar 29, 2007 | 11:46 AM
joeMama's Avatar
take it back!!
Old Mar 29, 2007 | 11:54 AM
MondoBongo's Avatar
what is your engine temp when this is happening? is it at normal operation temperature, or is it cold?
whenever i cold start my car the rpms will go up to around 2k and hang there until the engine starts to warm.
if i drive before the car has warmed up a bit, and press on the brake and let the clutch out, the idle will go back up. usually not as high as 2500, but it is something to consider. then when the engine begins to warm up either from idling or driving, the idle will drop down to 750 - 800 where it should normally be.
but, i would take it back to mitsu either way. while you still have a warranty, you should use it every chance you get.
