Meth Question
Old Apr 8, 2007 | 06:43 PM
Sully 18's Avatar
Originally Posted by Ultimate CC
yea i guarantee best price around
pmed
Old Apr 8, 2007 | 06:44 PM
Ultimate CC's Avatar
No corrosion with alky, and no, it doesn't make less power than meth. 100% is always capable of making more power than 50/50, too.
this is all relative to what i stated above...alky is slightly corrosive as well, theres no such thing as non corrosive with regards to meth and alky, just a scale of which is more than the other...
Old Apr 8, 2007 | 06:48 PM
Evoryder's Avatar
100% for best power gains... 50/50 will knock b4 100%meth...i've tried running on 50/50...car just didn't feel the same.
Old Apr 8, 2007 | 06:50 PM
I ran upwards of 28deg of timing on 50% meth and trapped 114-116 regularly on stock turbo with no issues, i played with timing up and down and different mixes and nozzle sizes and guess what, still trapped 114-116 with the occasional 117 due to tire spin...
Sully 18's Avatar
ugh knock.. this is driving me insane, going back n forth
Old Apr 8, 2007 | 06:56 PM
Evoryder's Avatar
I would go with a 70/30 mix...at least you don't have to worry about it being highly flammable/volatile and still get the power. 50/50 is nice, but not as nice as a higher meth mix...and it's definetly not corrosive.
Old Apr 8, 2007 | 06:59 PM
Sully 18's Avatar
where to buy 70/30 never even heard of that and im assuming u can run 70/30 on the snow kit
Old Apr 8, 2007 | 07:03 PM
Evoryder's Avatar
just on meth or the other magical goodies
Old Apr 8, 2007 | 07:05 PM
no that wasn't on the nitromethane...nitromethane i began using just before i blew my tranny and tcase haha...
Old Apr 8, 2007 | 07:06 PM
nitromethane you could run 1000 degrees of timing haha...
Old Apr 8, 2007 | 07:08 PM
Evoryder's Avatar
you mix it yourself.
measure out 30% distilled water and 70% meth...measuring container of some sort. 10pts on it...pour water to pt3 and then fill the rest to 10 with meth.
Old Apr 8, 2007 | 07:09 PM
Evoryder's Avatar
thats all? lol
Old Apr 8, 2007 | 07:14 PM
kmcconn9's Avatar
Man, decisions decisions....either 70/30 or 100%....
At 70/30 it will still be just as corrosive as 100% denatured alcohol
So, is there that big of a difference between mixing meth and water over just pure meth as far as being corrosive...
Old Apr 8, 2007 | 07:22 PM
Sully 18's Avatar
so its back to being corrosive...
Old Apr 8, 2007 | 07:34 PM
fromWRXtoEVO's Avatar
Exagerations, speculations and missleading info. I am still waiting to see an actually methanol pump kit to fail due to corrosion, please show me.
Methanol might be corrosive but as mentioned before people like to exagerate. The methnaol kits have tough components, the lines are stain steel braided, the tank is hard plastic and will never corrode, the nozzle is made of brass and I never see corrosion on them and as far is the pump it might have a rubber base seal but you can drop a tablespoon of Klootz oil in your meth tank if you are concern.
We need to stop fueling the fear with the methanol usage, it is not as harmful as the people think. There are many ways around(90 meth-10 water) 50 meth-50 water) and you can also use pure Alcohol.
Go and buy your methanol kit because I predict that nothing will happen. Trevor has been running methanol/alcohol on his dodge Stealth for 7 years and never had any issues. And who is Trevor?
just watch:
http://www.technicaltuning.com/gtonemesis/1039.wmv
my .2c
Carlos
