will the pull fan thats inside the engine bay come on with the car idle?
Old Apr 9, 2007 | 02:07 PM
Late Apex's Avatar
i searched but found no answer... will the fan come on with the car just idling? the fan behind the bumper obvious does while idle but what about the pull fan? is that for AC use only?
thanks
Old Apr 9, 2007 | 03:27 PM
evil4g63's Avatar
do u mean the fan between the radiator and the engine? if so then yes it does come on at idle if the temp gets to high
Old Apr 9, 2007 | 07:26 PM
barneyb's Avatar
thanks
The pull fan is the radiator fan. So it should come on occasionally. The push fan is the A/C fan. It should run when the A/C is on. The A/C is on if the heater is set to defrost so you might want to check for this.
