Turbo gone bad? Diagnosis question. Pics!
It very well could be the turbo, and since you already have it apart why not swap it out. I would just hate to see you clean all of those parts out of oil and then have the same thing happen again in the very near future.
The problem I had resulted in no oil in the exhaust runners, basically none in the intake except for in the inlet of the turbo, and a bunch in the exhaust and IC pipes.
Good luck with the project, the fmic cleaning is not fun, especially if you have to do it twice.
Honestly, I would put the pcv valve going straight back into the intake manifold for the time being. Although then you wont know what caused the problem, but you would stand a better chance against getting oil all thoughout your pipes again.
Dont trash that spare turbo just yet...
Also make sure the pcv valve holds pressure, new ones are cheap insurance from blowing tons of oil into the turbo inlet tract.
milburn
I say send the 05 turbo into FP and get yourself the Evo Green. My god that turbo is wicked awesome cool man! I think I am getting 9mpg since I installed it, since I cant keep my foot of the pedal now. *sigh* I think I need to go for a drive, back in a few....
Turbine oil seal has gone.
It not rocket science to rebuild the turbo. just by the seal rebuild kit. Replace the seals- get the turbo balanced and off you go.
It took me around 1/2 hr, once I removed the turbo from the car, to replace the seals- no more smoke on decel.
It will happen to all turbos at some time or another and is so easy and cheap ($100) to do.
As you already have the turbo apart- you have done half the work!
wow i had this exact thing happen to me yesterday exact same situation. Wondering if you know if its the pvc or the turbo im also on the stock one.
the pvc is the one on the back left of the valve cover when facing the motor correct?
evoisdream
evoisdream
You can get most replacement parts direct from Forced Performances web page.
http://store.forcedperformance.net/m...de=Turbo-Parts
Call them before you order anything though to ensure you are getting the right stuff. Robert, at FP, is extremely helpful!
I had this happen to me on a very cold day. The car was smoking bad. I found that the oil catch can hoses had condensation that froze and plugged up the hoses which caused excessive crankcase pressure. Oil was being pumped into the intake manifold and then being burned off. I pulled over immedietly and took the catch can out of the loop. It then stopped smoking.
The saga continues...
Took it to the track last weekend with the replacement turbo and had another big problem...
I blew the dipstick out and sprayed oil all over the place. Cleaned it up, and went back out, came in with a smoking car and still had oil all over the place, but not from the dipstick this time. Took a bunch more runs to figure out where it was coming from and it seems it was blowing out of the oil fill cap on the top of the valve cover.
The only thing that I can figure out is that I'm not venting enough of the pressure fast enough and causing some serious crankcase pressure.
With enough crankcase pressure, it would have driven the oil back up the oil drain from the turbo and forced it out the easiest path, the oil seals on the turbo... I may have not blown the turbo afterall.
I'm creating new paths for venting, and it should not be a problem anymore... we'll have to see after some testing.
Any other comments?
Any other comments?
