Turbo gone bad? Diagnosis question. Pics!
Old Apr 17, 2007 | 12:52 PM
  #31
bluebyu36's Avatar
then he should do a leak down test....
Old Apr 17, 2007 | 01:34 PM
  #32
Fireball's Avatar
Originally Posted by bluebyu36
and u said the comp.test was good cause it sound like a piston ring...
Well, compression was still good, so I have a leakdown tester coming. If it's a bad ring, the compression test would could still just be just fine.
Old Apr 17, 2007 | 06:41 PM
  #33
wizzo 8's Avatar
I personally dont like compression tests. Yea the are good for some diagnosis but a leak down test will tell everything and is a better indication of what is wrong with your engine.
Old Apr 18, 2007 | 04:56 AM
  #34
Fireball's Avatar
How do you easily tell TDC for each cylinder?
Old Apr 18, 2007 | 06:37 AM
  #35
WaxThis2005's Avatar
Hopefully this isnt anything big with the engine! Keep us posted, good luck Bryan!
Old Apr 18, 2007 | 08:49 AM
  #36
RazorLab's Avatar
Put a screwdriver on top of the piston and rotate the crank. Once you get a feel for it you will know when the screwdriver is at it's highest, hence TDC.
Old Apr 26, 2007 | 10:47 AM
  #37
Dapper Dan's Avatar
ever figure out your problem?
onlynamenotused
15
Oct 13, 2018 11:48 AM
Bmurray
190
Sep 20, 2017 06:01 PM
plan:b
Dec 25, 2015 09:07 AM
Slo_crx1
Jul 6, 2011 02:38 AM
1st.evo.guy.
May 23, 2011 09:26 PM
