03 Evo dropping a sylinder at idle
Old May 15, 2007 | 12:58 PM
sonicnofadz's Avatar
Just out of curiosity, what kind of cylinder compression are you getting?
laakness's Avatar
Wow, so you never changed the timing belt/tensioner at 60K?
That's awesome that it never skipped a tooth/teeth under boost
Old May 15, 2007 | 03:51 PM
Fitz's Avatar
Timing belt was changed at 60k and again at 85k when I had the timing gears put on.
Hence:
FWIW, the tensioner had 101,000 miles on it and two re-compressions when it finally gave up
The first re-compression of the hydraulic tensioner @ 60k, and the second at 85k.
I'm lucky it never hopped a tooth under boost. No argument there.
Fitz
Old May 15, 2007 | 03:56 PM
Fitz's Avatar
PS. The mis-spelling in the title of this post is killing me... and it won't let me edit.. would one of the moderators be so kind to throw a "c" in there.
Thanks,
Fitz
