Trouble with A/F ratio
Old Apr 10, 2007 | 09:20 AM
dean evo9's Avatar
after installing cos cams in my 9 , at idle i have a very high a/f ratio , car also runs rough, i have a aem wideband , did all the normal trouble shoot before posting , boost leak test , fuel system test , than i unpluged the oxygen senser on the 10.5 hot side and nothing happened it still ran lean , and rough ,can the oxygen senser be the problem??
Old Apr 10, 2007 | 10:02 AM
dean evo9's Avatar
bump
Old Apr 10, 2007 | 12:08 PM
dean evo9's Avatar
can anyone help
any help would be greatly appreated, does the oxygen senser scrwed into the 10.5 hot side of the turbo alter A/F ratio ??, i unpluged mine and theres no change to a rough running lean idling moter, thanks
Old Apr 10, 2007 | 02:35 PM
yikez's Avatar
well naturally the cosi cams are gona have a rougher idle then lets say the GSC S1's. However, i don't think they they should be too rough.
You need a tune anyways. Get a reflash or custom tune and that should help out a lot.
How lean are we talking?
