5th Gear part numbers for Evo IX
Old Apr 10, 2007 | 11:05 PM
kw273's Avatar
Anyone know one or both of the following
1) parts numbers for Evo IX 5th gear syncro repair
and / or
2) parts and part numbers required for switching and Evo IX 5th gear to a taller 5th gear (Evo VIII?)
Thanks
Old Apr 12, 2007 | 03:37 PM
kw273's Avatar
Anyone know? Mitsubishi parts has not been very responsive to emails...
Old Apr 12, 2007 | 04:36 PM
sonicnofadz's Avatar
I could be wrong, but I do not think these gears have part numbers. Try messaging spins4, he works at a Mitsubishi dealership and could tell you for sure. Your going to probably have to replace the entire cluster gearset, not just one gear, if you plan on going with a taller 5th gear.
Old Apr 12, 2007 | 08:04 PM
vwjeff's Avatar
the viii 5th will only drop you 150 to 200 rpm
Old Apr 13, 2007 | 09:25 AM
kw273's Avatar
Only 100-200 rpm? I thought there was a way to get a taller cruising gear, maybe not the Evo VIII gear then...
Thanks sonicnofadz, I'll pm spin4 and see what he can tell me.
Only reason I ask is I have a slight 5th gear grind and if i'm going to have to take down the tranny anyway, was thinking to maybe do this at the same time.
Old Apr 24, 2007 | 09:36 PM
EVOIXMR8916's Avatar
droping in a taller gear wont help if anything go with a taller gear in 4th therfore creating less work for syncros going from 4th to 5th in shifts...
Old Apr 24, 2007 | 09:40 PM
fromWRXtoEVO's Avatar
KW273,
I am very curious, are you having issues with the 5th gear? mine grings slightly if you shift fast. Please let me know what your action path would be. I am thinking about taking mine to the dealer.
Carlos
