How A Twin Disc Clutch Works???
Old Apr 13, 2007 | 04:42 PM
mighty4g63's Avatar
Sorry If This A Repost Guys...but How Does A Twin Disc Clutch Work?????
Old Apr 13, 2007 | 04:48 PM
mack4477's Avatar
i'm sure many guys here can explain the details about this. BUT, wouldn't it have been easier to search exedy's website to read up on this??
Old Apr 13, 2007 | 05:07 PM
sonicnofadz's Avatar
A twin disc works by effectly doubling the amount of frictional area used when connecting the engine to the drivetrain, which doubles the amount of grip from the engine to the transmission (Same theory applies when people choose to use wider tires and rims, they want a bigger "contact patch" with the road). There are many ways a clutch can be designed to increase grip from the engine to the transmission, increasing the frictional area is only one them. Multi disc clutch setups are favorable (despite their high price) because they offer more grip without neccessarily increasing the clamping load of the pressure plate (which is very bad for the crankshaft).
On a regular single disc setup, the friction disc rubs on the flywheel's face, and on the pressure plate's face (two fricitional surfaces). The frictional disc itself is connected to the transmission via the input shaft, and the flywheel and pressure plate are bolted together (they are connected to the engine via the crankshaft).
On a twin disc setup, there is a center plate which rotates with the flywheel (effectly this center plate is an extension of the flywheel). You can consider this plate to be a second flywheel. Sandwiched in between the two flywheels is the first friction disc. On the other side of of this center plate, there is the second friction disc. After the the second friction disc comes the face of the pressure plate. Here is the order:
flywheel -> friction disc 1 -> center plate -> friction disc 2 -> pressure plate
This makes for a total 4 frictional faces (flywheel, two sides for the center plate, and the pressure plate). This is DOUBLE the amount of frictional surface area than a single disc setup.
To visualize how this kind of setup works, you have to keep in mind what is attached to what. There are only two rotating bodies here (think to yourself "engine speed" & "drivetrain speed"). The first body is the a splined input shaft from the transmission that is connected to the two friction discs (the friction discs spin with the transmission). The two friction discs spin together because they are both connected to the transmission's input shaft. The second body is the flywheel, center plate, and pressure plate which are all bolted to each other and spin together in unison with the engine's crankshaft. Any difference in rotational speeds between these two rotating bodies happens when the clutch pedal is depressed down (when the clutch disengaged) or if the clutch is slipping under power.
Old Apr 13, 2007 | 09:27 PM
mudduck's Avatar
^^^ very informative post there. Thanks!
Simon Pugmire
May 21, 2017 07:42 PM
Freddy302
Oct 12, 2016 09:15 PM
martinPL
Jun 1, 2016 09:22 PM
romogst
Aug 22, 2013 06:57 AM
CARLITOEVO
Feb 25, 2010 04:37 PM
