hey guys newbie here need some advice
Old Apr 14, 2007 | 03:25 PM
thedragon's Avatar
im drivin a 2005 evo 8 so far my mods are tbe, exh headers, evc boost controller set at 22.5, wal. fuel pump, 272 cams, fujita air intake and upper intercooler pipes, hks bov, megan racing o2 housing, stage 2 act clutch and a reflash runin on pump 93. my question is this, on the dyno dynamics dyno i only hit 270 at the wheels. i know this dyno is conservative but damn. is my tuner trying to make more money by havin me keep commin back or is that dyno pull right for my set up. thanks
Old Apr 14, 2007 | 03:31 PM
NIevo's Avatar
Well do you know what other similar cars are doing on that dyno. Your power seems low but maybe its an extremely low reading dyno. Did they check your car for problems? Such as compression and boost leaks?
Old Apr 14, 2007 | 03:32 PM
NIevo's Avatar
You should be 320+whp FWIW, depending on the dyno.
Old Apr 14, 2007 | 03:33 PM
thedragon's Avatar
no boost leaks no problems
bluebyu36's Avatar
ya def do a compression test thatz crazy low maybe boost leak.......
Old Apr 14, 2007 | 03:34 PM
bluebyu36's Avatar
what do u mean no problem's how do u know?
Old Apr 14, 2007 | 03:36 PM
thedragon's Avatar
i dont really wishfull thinkin
Old Apr 14, 2007 | 03:37 PM
thedragon's Avatar
im in westchester were can i go to get it checked out
Old Apr 14, 2007 | 03:46 PM
bluebyu36's Avatar
tubo trix,pruven,1320,racing results,no limit.....
Old Apr 14, 2007 | 03:47 PM
thedragon's Avatar
thanks
Old Apr 14, 2007 | 03:48 PM
bluebyu36's Avatar
shure good luck
Old Apr 14, 2007 | 03:49 PM
thedragon's Avatar
if its compression what will i have to do to fix it,and how much
Old Apr 14, 2007 | 03:58 PM
thedragon's Avatar
i also noticed a lot of white smoke comin out of the exhaust could that be a sign of someting wrong
Old Apr 14, 2007 | 04:34 PM
ries's Avatar
maybe a blown headgasket if your getting the white smoke...
Old Apr 16, 2007 | 05:39 PM
thedragon's Avatar
just an update, i got my car checked out and i blew the head gasket. thanks for the help ill keep everyone posted when i get the car redynoed. peace
