Shifting Question
Old Apr 16, 2007 | 07:11 AM
jnathan68's Avatar
Shifting Question
I have an Evo IX and in normally day to day driving, shift from 1st to 2nd is smooth. However, when I am WOT and try to do a quick shift from 1st to 2nd, it seems like 2nd is just out of reach and I can't get it into gear. Almost like there isn't enough gear lever movement available to get it into 2nd. There is no grinding and when I let off a little, goes into 2nd fine.
Almost seems like it just needs a small amount of linkage adjustment. I searched and all I found was a clutch adjustment.
Is there a way to adjust the linkage slightly? Will a clutch adjustment do it?
Any thoughts would be appreciated (on topic, of course). Thanks.
Old Apr 16, 2007 | 07:16 AM
DanJ's Avatar
I say try adjusting the clutch a little and see if that helps you out.
Old Apr 16, 2007 | 07:17 AM
TeStUdO's Avatar
Adjust the clutch and see how that works. If you arent getting any grinding then the little adjustment of the clutch should make it fine.
Old Apr 16, 2007 | 02:33 PM
jnathan68's Avatar
Thanks, I will give that a try.
