Air silenecer/airbox?
Old Jun 11, 2003 | 07:42 AM
Lightsped's Avatar
Question Air silenecer/airbox?
Does the Evo8 come with any kind of restricitive air silencer/airbox?
All cars I have tinkered with in the past have always had a airsilencer/airbox stuffed up in the front fender that could easily be removed allowing for more engine and/or turbo sound.....
Old Jun 11, 2003 | 08:24 AM
2Cool's Avatar
Nope. It has a cold air duct from the front edge of the hood into the air box. No silencer (like the Mustang had and still has today).
Old Jun 11, 2003 | 12:09 PM
MalibuJack's Avatar
Its actually a good example of a well designed air-box.. Since its enclosed, it does significantly reduce intake noise, therefore it is still a silencer.
The jury is still out as to whether its restrictive, whether its cold-air feature makes much of a difference, etc..
However my personal experience is it does become a restriction at higher RPM's if you increase your boost levels (19-20psi to redline or obviously higher boost levels, thats just what I am running)
If you have an S-AFC or some other air fuel computer, you can actually see a difference in the Karmann frequency at Idle, and at different throttle points, the numbers on my open element filter were always a little higher. In theory it can make the engine run a little rich until it learns to compensate for it, or you reset the ECU..
partsman t
Jun 3, 2017 01:52 AM
EM1 to EVO
May 27, 2017 05:28 PM
germanmike954
Jan 9, 2017 12:21 PM
asng
17
Aug 6, 2005 12:19 AM
nubby
10
Sep 11, 2003 06:02 PM
