Power gains from Buschur Ported Exhuast Manifold
Old Apr 18, 2007 | 07:09 PM
dudical26's Avatar
Well after spending over an hour searching Buschur's dyno thread I have not been able to find the info I am looking for.
I want to know how much power porting a stock exhaust manifold will add.
I can only find when DB added ported exhaust manifold and ported hot side and ported 02 housing.
Any one know how much power just a ported exhaust manifold makes?
Old Apr 18, 2007 | 07:13 PM
EvoDan2004's Avatar
welp here's the deal. i have no idea but my friend used to pull on my car mega hard. maby 3 cars from 60mph to 120ish. now when i had the ported 10.5, manifold and added a o2 housing. UNTUNED at that time i pull'd 4 at the least from 65mph to ABOUT 120. i would say it added good power. then when i had that setup tuned. HAHAHAHAHAHAAHA 4 cars turn'd into truck lenths.
Old Apr 18, 2007 | 07:17 PM
EVO8904's Avatar
I ported my exhaust manifold myself. All it costed was some time and afew dremel wheels.
Exciting News's Avatar
Might be hard pressed to find someone who did before and after dynos with just a ported manifold. My guess is not that much by itself. 2whp?
Old Apr 18, 2007 | 07:27 PM
dudical26's Avatar
How is this in anyway helpful to determining how much power porting a manifold adds?
Please only post if you have actual experience with before after dyno.
Thanks
Old Apr 18, 2007 | 08:34 PM
scheides's Avatar
EvoM Moderator
According to my notes, ported exhaust manifold should be worth about 5whp. Add a SS o2 housing and make it 15-20whp gain total.
Old Apr 18, 2007 | 08:46 PM
dudical26's Avatar
"Notes" Got any links? How did you arrive at this conclusion.
Thanks for the post.
Old Apr 18, 2007 | 08:51 PM
Fast Frank's Avatar
Buschur said 5whp on another post
Just for fun- He also said 15whp for ported stock intake & 65mm TB
Old Apr 18, 2007 | 08:52 PM
EVOlutionary's Avatar
It will make between 5 and 10 whp depending on your level of tune. The more power your car makes the more of a restriction it is. If you are at 300whp it may make 5. If you are at 400whp it may make 10. For either of those it may make 7 (depending on your car). For the $200 it is a good mod. Of course it works best if your hotside is also ported to match. . . and then if that's ported you should have your 02 housing ported to match . . . it all kind of works together. . .
EVOlutionary
Old Apr 18, 2007 | 08:56 PM
dudical26's Avatar
Do you have a link, I could not find him saying that?
Old Apr 18, 2007 | 08:57 PM
dudical26's Avatar
EVOlutionary
What makes you say this, experience or opinion?
I'm not knocking your input, I just like to act on proof rather than speculation.
Thanks
Old Apr 18, 2007 | 09:09 PM
Fast Frank's Avatar
It's on here somewhere I read it on an unrelated AMS post earlier
Sorry can't find it now-
Old Apr 18, 2007 | 09:13 PM
scheides's Avatar
EvoM Moderator
Search, search, read all the way through a thread, and then search some more, that's all I gotta say. 5whp gains were around the 300-375whp mark on a stockish turbo (8 or 20g-9-5) so obviously you'll see more w/ a bigger setup.
+1 on the 15whp gains from ported intake manifold and throttle body.
Old Apr 19, 2007 | 04:36 AM
EVO8904's Avatar
Thanks
Just trying to help the guy save some money I would thing that a P&P manifold would make additional power.
Old Apr 19, 2007 | 04:45 AM
Bosshog's Avatar
5hp
I searched for the same thing forever.
Below you can find DB's answer to me when I enquired about the ported stock manifold:
**I can gaurantee a 5 hp increase over stock IF the turbine housing and 02 housing are addressed first. IF you leave the turbine housing a 9.8 unported piece and the 02 housing unported you will not gain anything from the manifold.
I could not do an exchange as I am located abroad. After thinking about gains vs door to door cost (including installation, shipping, exhaust manifold seal) I decided to go with the FR pro-stock manifold.
