Quick question about the catalytic converter. .
Old Apr 19, 2007 | 04:18 AM
subrwho's Avatar
Hey guys,
Today I was putting on my new exhaust and everything went great. . But then I got to tightening the final bolt (one of the nuts that tighten on the the stud on the cat) and I think the bolt stripped some how. . (because it will only go so tight the just back out. . ) So my question is, will the actual bolts that are attached to the cat just pound out with a hammer? (I'd like to just put new bolts in) Thanks guys!
Old Apr 19, 2007 | 04:28 AM
EvoLutionized8's Avatar
you will need to tap them out due to them being casted in the original cat. It's not a huge deal, because you can drill them out and use a bolt with nut and fix it easily. Either way you should be fine..
Old Apr 19, 2007 | 04:30 AM
subrwho's Avatar
So should they just tap out with a hammer?
Thanks for your help by the way!
Old Apr 19, 2007 | 04:36 AM
tap out with tap out bits.. not exactly with a hammer, but a drill... good luck
Old Apr 19, 2007 | 04:46 AM
subrwho's Avatar
Tap out bits? Ive never heard of them. . can you get them at say Autozone? Are they costly?
Old Apr 19, 2007 | 05:44 AM
subrwho's Avatar
ttt
