Invidia 02 housing hardware
Old Apr 20, 2007 | 01:43 PM
meckert's Avatar
I need to install an Invidia 02 housing....I was thinking it best to replace all the hardware ( nuts bolts) at install. (at turbo)---needless to say when I got the housing, I didn't get new hardware..Can someone let me know the number and size ( dia, and length) of the needed hardware specifically for the Housing (02) to the Turbo.. thx. Pls advise.
Old Apr 20, 2007 | 04:23 PM
mikesevo8's Avatar
The sizes are 10mm x 1.25mm pitch. Bolts are 25mm long
Here are the PNs of all the official fasteners..
Bolt - MD062961
Nut - MD050073
Stud - MR224441
Washer - MD132933
You can order whatever combo you want. You need 2 studs minimum, and 3 bolts,
but you do get all 5 locations as studs, then get the nuts and washers.
Order from www.mitsubishiparts.net if you want the "real" parts
Or, if your turbo has the studs, and they are in good shape, then go to Home Depot, NAPA, etc.,
and buy the bolts, nuts, washers. You want hardened - grade 8.8 fasteners
Old Apr 20, 2007 | 04:26 PM
meckert's Avatar
Fantastic---Thanks for the info..its exactly what I wanted/needed. I appreciate you taking the time. Regards, Mike.
STM Tuned
Jul 19, 2018 01:12 PM
Spoolin4g63
15
Oct 30, 2016 10:47 AM
Evo-IXse06
Mar 30, 2016 08:53 PM
SavEVOIX
Sep 6, 2011 09:09 PM
jordo
37
Jan 10, 2007 08:36 AM
