whats ur spool up like on a gt3065
no way!!!!... why not just go for the 3076r? thats what im running and once my boost spiked to 28 psi...crazy pull....but then i stopped and turned the boost down...scary! im runnin injectors alky and stock block
I run my car on straight 94 octane for daily driving and 22-23psi. My car is still fun and powerful. Like that.... my car made 398whp on our Mustang dyno. I do NOT run alcohol. Everyone has their preference and that is mine. I run straight 94 octane or straight race gas. Would it make more power and be even more fun to drive? Yes im sure it would. I just didnt want the hassle of messing with filling the reservoir, worrying about it not spraying, etc...
Like I said on STRAIGHT 94 octane my car makes 398whp and on C16 it put down 505whp. At 4400rpm I will hit 20psi.
My car does not fall off on power to be honest. It pulls HARD all the way through. You can see on the dyno graphs that it makes power until you lift off of the gas.
If you want something "close to stock" lag I would recommend the 20G-9LT. It flows just as much air as a 50 trim and its quite a bit cheaper. The revolver cams you have though I really dont think would pair up nice with anything under the 3065.
If you have any questions about this turbo please feel free to ask. I'll be glad to lend a hand. I was the first person to try/run this turbo on an Evo.
Not true!
My car made 415 @24psi dynodynamics and 500 @28psi on C16 with a flash. I'm going to the AEM this week and expect to make 25 more at 24 and 30-40 more at 28
full boost is around 5k
-Kyle
-Kyle
i have almost the same mods as the o/p and again im looking for a turbo. i ben talking with david and right now its between a 20glt and there 3065.
im just worried i might pick a kit i wanted more out of or it has to much lag.
No problem. I actually just did in this thread.
https://www.evolutionm.net/forums/sh...d.php?t=266112
what block you got again?? is it safe to shift at the level like it is at 7k?? on the streets i shift at 7k. at the track i let it go a bit longer.
i want 8k safe on the street and maby i tad more on the track. or am i just asking for truble???
2.0L Eclipse GSX, HKS 272's, headstuds/MLS gasket as far as motor work...FP3065 with 44mm TiAL, custom 3" o2 and a turboback and all proper supporting mods, I get 22psi by 3900rpms. Evo has a much better flowing head and higher compression (8.3:1 vs. 8.8:1 on the Evo), you'll spool that turbo on the Evo sooner.
I have shifted mine over 8000 at the track numerous times and close to 8000 on the street. As long as you have a good tune it shouldnt be an issue especially with forged internals. Stock block I would be a bit weary.
We have seen the stock rod bolts stretch so high revving and big power does have the chance to cause issues on the stock block (or any block for that matter). I was not affraid to do it. If it breaks it needed fixed anyway.
With a forged bottom end 8000 will not be an issue.Our stage 3 block has revved to 9500 and a bit higher. I did rev my stock block to 8000 while making 462 on our dyno. Was it a good decision? Probably not. Its a good chance the stock rod could have caused some damage. Would I recommend it to a customer? No not really. Thats the customers decision.
I also really hate how they call themselves "THE SHOP", they might be good guys but that name really bothers me.
<------dsm owner
He must be guestimating where it starts to spool by looking at his boost guage and not checking his logs. 3900 is like 5th gear under load with a stroker type stuff.
. If you're not going to run meth, go with the 50 Trim.
