More dyno results: BR Exhaust, intake, S-AFC
Today we added a Super AFC and a mechanical boost controller to our Evo. (Previous mods: Buschur Racing intake and turbo-back catless exhaust.)
The chart above compares the stock (no mods) dyno curve with the final, all-mods run. Compared to just intake and exhaust, we picked up 30 horsepower at the wheels with the S-AFC. The boost controller gave another five or so, and smoothed out the boost curve (the factory solenoid has that funny boost drop at 4500 rpm).
Not bad for a little bit of work and a few bolt-on parts! I love this car.
You can see more of my dyno charts here.
--Dan
Mach V Motorsports
MachEVO.com
--Dan
Mach V Motorsports
MachEVO.com
Originally posted by Stinkapuss
Nice Dan, I dyno'd right after you and was able to pull 289/271 out of it. Not bad for the humidity we had yesterday.
Good job.
--Dan
Mach V
MachEVO.com
Hardly any cars pull straight up to redline. If you look at just about any dyno chart they'll have similar dropoffs past peak (duh) hp/tq. Just because the engine's working harder does not mean it's making more power.
Originally posted by AustinEvo8
Dan, why the huge dips around 5500K???
In the case of this graph, the torque is falling, but not as fast as RPM's are increasing, to hp keeps going up as revs rise.
(If you didn't know, hp is just a number that derives from torque and RPM. The exact formula for hp is torque (in ft-lbs) * rpm/5252.)
--Dan
Mach V
MachEVO.com
Originally posted by chronohunter
Isn't that where the timing is getting pulled because of knock? The car stock has too much advance above 5k.
(Factory torque curve is dark red above, modded car torque is dark blue.)
Honestly, I wouldn't over-analyze a single dyno graph. Undulations in torque delivery are normal, and won't be exactly the same from one dyno run to the next. What I look at is the overall shape of the curve, and the area underneath.
--Dan
Mach V
Originally posted by mad_VIII
Thats a standard 2wd dyno right?? Just disconnecting the drive shaft??
--Dan
Mach V
MachEVO.com
Originally posted by Mach V Dan
I don't know about that. If that's the case, are you asserting that the factory torque falls off in the same way because of knock? Every car has a natural torque curve, as mentioned above. You're not going to find one that has level torque out to redline
--Dan
Mach V
--Dan
Mach V
Having said that the gains are still quite good with the SAFC, it's the area under the curve that the timing adjustment really helps. Do some searching, the info is out there
I understand and agree with all that...however Shiv and alfriedesq...
I'm not asking how to get more or better results; we have plenty more ugprades in store for our car. Some of them may involve timing changes, but probably not for a while.
--Dan
Mach V
MachEVO.com
