Evo VIII to VR-4 Galant
Old Apr 22, 2007 | 09:12 AM
jroller's Avatar
Just a quick ? I have an VIII would like to put the EVOGreen on and a Galant with the small 16g. Can i just bolt the Evos turbo onto the VR-4 no prob? Is it worth it? Or should I just leave the small 16g alone. Sidenote the galant has rc injectors
Old Apr 22, 2007 | 09:26 AM
jroller's Avatar
bump?
Old Apr 22, 2007 | 09:29 AM
matyb's Avatar
look at the physical shape of the turbo they dont work.
Old Apr 22, 2007 | 09:30 AM
dsmythe2's Avatar
I don't think so. VIII turbo spins reverse, hence the R in the part number. 4G63 in the VR-4 is more like the DSM with standard turbo.
Old Apr 22, 2007 | 09:31 AM
EVO8_PR's Avatar
If you have and EVO VIII, by just looking at the two turbos you will notice that the bolt pattern is different and their orientation is also reversed...
Old Apr 22, 2007 | 09:39 AM
jroller's Avatar
The vr-4 is in Ohio the Evo is in Cali so I couldnt compare but thanks.
Old Apr 22, 2007 | 09:43 AM
matyb's Avatar
oh that makes sense now. ^^^
look on-line at pics and you'll see that they are reversed as said above.
Old Apr 22, 2007 | 09:50 AM
DSMorBUST's Avatar
an evo iii 16g will work but not an evo viii turbo.. no way... unless you fab up something custom??
Old Apr 22, 2007 | 06:52 PM
CO_VR4's Avatar
But a normal DSM Evo Green will work just fine.
