K&N Cone Filter?
Old Jun 12, 2003 | 05:20 PM
StreetPowerEvo's Avatar
And finally RMR's filter kit, from their website. You can see the two seperate pieces (filter + L bracket). I have pics of it installed as well if you want.
Old Jun 12, 2003 | 06:16 PM
Shahul X's Avatar
I have a K&N intak that was originally designed for a 3000Gt, its much larger than the bashur's
-Shahul
Old Jun 12, 2003 | 06:24 PM
petem's Avatar
Re: K&N Cone Filter?
[QUOTE]Originally posted by Evo11V
my friend installed a cone filter in his evo last week,
its definatelly louder, but not faster. Personally I dont think they improve performance. Those are open air filters inside the engine bay, so much heat gets to them that they probably decrease performance.
I dont know I could be wrong, but then how come ralliart and hks make carbon fiber air boxes and regular high flow replacement filters?
Somebody please explain this whole K&N thing.
Old Jun 12, 2003 | 06:31 PM
wmcorcor's Avatar
Good question. I was leaning toward a stock drop in filter from K&N or Ralliart. I've always heard the drop in's get cleaner cooler air as opposed to the cone. I also wonder how Mitsubishi will view the cone filter with a warranty claim.
Anyone tried both?
Old Jun 12, 2003 | 06:59 PM
evo1's Avatar
Re: Re: K&N Cone Filter?
[QUOTE]Originally posted by petem
HKS does not make a drop-in filter solution; however, RalliArt, K&N, and Monster Sport do. HKS makes a racing suction kit that utilizes an open air filter. As far as Carbon Fiber air boxes ... I have seen one from Monster Sport ... but never from RalliArt or HKS. I will not attempt to answer your question as to which works better since I do not know myself .... but I chose to go with a RalliArt drop-in until someone proves that an open filter improves induction volume as well as hp/tq.
Old Jun 12, 2003 | 07:07 PM
wmcorcor's Avatar
I agree evo1. I've always had great luck with K&N drop-ins and until I see better this just seems to be the easiest, safest, quiet-est and most warranty-friendly option.
If someone shows me a cone filter is better and I can do a cone filter easily then I'd be interested.
Old Jun 12, 2003 | 07:18 PM
chronohunter's Avatar
Originally posted by StreetPowerEvo
OK, as requested here are the pictures of the Buschur filter.
As you can see, the MAS adapter is actually attached as the bottom of the filter, unlike the RMR where it is two pieces. Both are approx the same size filter. I did not find any markings indicating filter make or manufacturer however.
No wonder people report that the power and response are not as good as stock. Look at the transition between the filter and entering the MAS, that is as bad as it could be made. The abrubt 90degree turn will create turbulence that will REDUCE the amount of air entering into the engine (at certain RPM's). It needs a bell of some sort to insure smooth aiflow through the MAS, the turbulent air can also cause the MAS to misread
Who makes a CAI kit that has some sort of bell and a large filter that is K&N brand? The bigger the better on the filter.
Old Jun 12, 2003 | 08:01 PM
evo1's Avatar
Nothing for evo yet, but AEM is working on one and should have it soon ... I heard that K&N displayed an evo CAI kit at a recent show as well ... but they haven't released it yet.
Old Jun 13, 2003 | 08:47 AM
Jonasan50's Avatar
[QUOTE]Originally posted by chronohunter
[B]
On the contrary, I do have the Buschur filter kit on my EVO. The throttle response did increase immediately.. David Buschur advises of a 4hp increase, but that is something that you can barely feel at all.. The butt dyno did notice a slight difference.. Maybe that was just me in the hype, but there is a difference, good not bad... My .02....
Old Jun 13, 2003 | 10:03 AM
Evo11V's Avatar
Veteran: Army
Now that you say it the Evo's engine does put out a lot of heat. WIth a cone filter this could be a problem, like stated before decreasing performance instead of increasing. We really need a dyno chart that can possiably solve this possiable problem. Another answer could be a cold air intake with the cone filter, cant go wrong there. Also in relation to the shot ram cone intakes although it does intake more heat... correct me if i'm wrong but doesnt that big *** intercooler cool the air anyway? Also the engine has a huge amount of air flow and allows great heat extraction. Still there is a possiable problem there.
Does anyone have a dyno chart with a stock airbox compared to a cone intake, and even better the stock airbox compared to a cone intake and a cold airintake. We really need someone with expert knowlege to take this somewhere
Old Jun 13, 2003 | 12:31 PM
rhyzin's Avatar
K&N FIPK Compatable Kits
57-1500-1 3000GT
57-5504-1 2G Eclipse GSX
All mitsu MAF adapter kits fit each other. The filters are shaped in a way that K&N *believes* help get better readings and performance based on the nature of Karman Vortex MAF sensors. They're just an adapter with an oval cone. There's no intake pipe replacement. there is a funnel shape to the adapter so intake airflow is smooth. the difference between the two models is that the eclipse one has a bolt on it's end for mounting purposes while the 3000GT has 2 separate brackets for mounting. Also the 3000GT is about $180 while the Eclipse one is around $120.
Old Jun 13, 2003 | 12:36 PM
maki's Avatar
the bottom line is, a cone filters dont work, especially in cars like evo, the stock air filter is too close to the turbo and the exhaust manifold. The best bet is to get a large carbon fiber air box and a drop in ralliart filter. But lets be honest 80% of evo;s already have cone filters.
Mod cheap, mod twice.
Old Jun 13, 2003 | 01:07 PM
Evo11V's Avatar
Veteran: Army
So how about the cold air intake? is it possiable?
