oil light problem
Old Apr 23, 2007 | 08:01 PM
MR DSM IX's Avatar
Exclamation oil light problem
hey every1, i have a little bit of a problem, and i hope its nothing major at all... when i start my car up and let it warm up, everything is fine, but its when after i drive it for a little while and then i let it idle, like comming to a stop at a red light, and its just under 1 thousand RPM, some time the oil light will flicker, but as soon as i tap on the gas pedal, and the RPM jumps a little it will turn of until it goes down to idle again... im thinking that it MIGHT be the oil pump internally, but it could also be the sensor externally or some ****... any thing? please help thank you
daryl
Old Apr 23, 2007 | 08:06 PM
joeymia's Avatar
have you checked your oil level? either you have have a bad oil pressure switch or your running low on oil. make sure to check the oil when the car is warm.
Old Apr 23, 2007 | 08:12 PM
MR DSM IX's Avatar
hey man the oil is perfect, and i hurd something about that switch, where is it and is it easily replaceable? or is it gonna tear my and my car a new *** hole...?
Old Apr 23, 2007 | 08:17 PM
joeymia's Avatar
its on the back of the engine block. why not take it to the dealer?
Old Apr 23, 2007 | 08:19 PM
MR DSM IX's Avatar
bc i've already had problem with them, u know how dealerships are, plus i think i might have to put my car back to stock and i dont really wanna do that untill i see wat the problem is, honestly, what do u think the problem is?
Old Apr 23, 2007 | 08:22 PM
SteVenQDZ's Avatar
i had the same problem.....but when i check my oil level it was above max level.. so i went to get an oil change yesterday... so far i havent seem the oil light flicker
Old Apr 23, 2007 | 08:35 PM
MR DSM IX's Avatar
hmm, well i changed my oil a few times since i'vebeen getting this problem. i might check that oil pressure switch, how much do u think it may cost?
Old Apr 23, 2007 | 10:41 PM
barneyb's Avatar
What weight oil are you running.
Old Apr 23, 2007 | 11:01 PM
TalonFiero's Avatar
I have been having the oil light flicker at idle when warm at around 700-800rpms running mobil 1 10w30. I have 13,000 miles on the IX MR. I know 90's mitsu oil sending units are known to be flaky and trip the oil light when the pressure drops (idle). Both my 94 and 95 Talon had this issue, guess it seems fitting I buy another mitsu and have the same issue again. :/
Old Apr 24, 2007 | 07:20 PM
barneyb's Avatar
Yeah, just checking if you were one of those people who thinks 0 weight oil is the key to horsepower.
From what I've read Evo's don't ordinarily do this. I'd try a new sender. If that doesn't fix it then it is probably time for a more serious investigation.
Old Apr 24, 2007 | 08:29 PM
MR DSM IX's Avatar
yea it hardly did it today bc i didnt run the car too hard lol but it still did it... the weight oil is 10w-30 mobile 1 synthetic factory stuff lol
Old Apr 25, 2007 | 12:19 PM
TalonFiero's Avatar
I noticed today that the oil light would not start to flicker at idle (stop light) until the oil temp got to about 70 degrees celsius or higher.
Old Apr 25, 2007 | 03:24 PM
MR DSM IX's Avatar
yes, most of the time, my oil light would come on after about 70 celceious, i might have to step it up with the greddy turbo synthetic oil or
Old Apr 25, 2007 | 03:36 PM
BLKEVO9's Avatar
mine is doing the same thing, after the temp gets to around 180 degrees, only at idle. i changed the oil to RP 10w-40. but its the same but my oil psi went up at idle. so im just going to try changing the factory part and see what happends.
Old Apr 25, 2007 | 05:29 PM
joeymia's Avatar
all you guys with the problem seem to be 9's... i would go to the dealer and reference this thread. its probably just a bad oil pressure switch but you never know...
