Some FPgreen spool data.
27 psi at 4160 rpm in 3rd gear:
Lower boost spools faster, full spool by 39XXrpm in 3rd: (Don't mind the boost hump as that is how I tuned my boost curve at that point.)
2.0L stock motor with ETS fmic. Nisei LICP, stock UICP. Unported stock 02 housing and manifold.
I was reading your post on norcal evo. after adding 20g-lt, you gained no power. added an intercooler - again no power. than put on an intake and gained 24whp. if I am not mistaken, later you say that the ecu adds a bunch of fuel on the track due to higher intake temperatures from the open filter.
I wonder if you would have solved the problem with a modified airbox (side cut across the snorkel) with a good drop in like works?
Bryan -- spool looks pretty nice. What sort of fuel are you using w/ a 27.4 psi peak? What are your thoughts on using Alk or meth to aid the 91 octane in Ca.?
100 octane. I don't actually run 27.4 psi. I run 26 on one of my tunes. I was just testing it. Meth would help 91 octane for sure. It's even better than 100 octane from what I have seen, but of course, another thing that could fail.
