Won't start HELP!
Old Apr 26, 2007 | 02:56 PM
LancerEVOmann's Avatar
Won't start HELP!
I just got home from work, turned the car off, got the mail, got back in and the engine won't even turn over. All electrical power in car is gone. When I press the remote lock button nothing happens. This came out of no where as the car was running perfectly until now. I had to manually lock all doors and walk back to my apt. Is this probably a dead battery or alternator?
Old Apr 26, 2007 | 03:18 PM
bump
Old Apr 26, 2007 | 03:49 PM
Kerr's Avatar
Fomer Vendor
Check the fuse's, or maybe a bad ground. I've never heard of a battery just completely dying.
Old Apr 26, 2007 | 07:11 PM
Ok, the negative battery terminal connection is cracked. When I wiggled it around the electriciy came back on in the car (open door beep, power windows, etc) but when I try to turn the car on it clicks but dies. No power again until I fiddle with the neg connection and same thing. Finally someone jumped me off and the car started. But the Anti-Lock brake light came on briefly and as I drove the car it almost died on me. Also the interior light was blinking in intensity.
I checked all fuses in the engine fuse box, none looked blown. Could all this be from a dead battery, or a dead battery and a bad negative battery connection?
Old Apr 26, 2007 | 07:49 PM
Kerr's Avatar
Fomer Vendor
Its all from the bad ground (- connection). Fix your ground and you should be fine.
Old Apr 26, 2007 | 07:53 PM
scottatyamaha's Avatar
This happened to you because you are a South Carolina Game **** fan. I am sorry.
Fer23evo9
Apr 1, 2017 05:20 PM
MichyMY10RA
Jun 4, 2015 01:32 AM
kanovic
Mar 18, 2015 05:40 PM
Zhang
Mar 18, 2011 07:16 AM
Jackyll
Apr 5, 2008 04:33 PM
