Buschur 20g-9LT
Old May 9, 2007 | 10:12 AM
El.BlueEvo9's Avatar
Just order one from Buschur, and sell your current turbo like I did and get some money back.
Old May 9, 2007 | 10:19 AM
sparky's Avatar
As Warrtalon states: the Buschur Racing 20G-LT turbo, is the same exact turbo as the Forced Performance EvoGreen turbo. They both are manufactured by Forced Performance Turbochargers, Inc. Buschur Racing only changes the nomenclature for marketing purposes.
Old May 9, 2007 | 11:30 AM
Erik@MIL.SPEC's Avatar
Is the 20g-9-5LT the same turbo as the EvoGreen?
Old May 9, 2007 | 11:31 AM
shivaswrath's Avatar
YES!!!!
Old May 9, 2007 | 11:32 AM
Originally Posted by shivaswrath
YES!!!!
What I wrote was a joke
this is the preferred way to do it currently since there is a HUGE back up on core exchange. . .I'm going to buy it new and just sell the Evo VIII turbo. . .you'll recoup the money one way or the other. . .
Old May 11, 2007 | 05:29 PM
kduncan01's Avatar
I just installed my 20G-LT and I dont get full boost (20PSI) until 4500RPM, is this normal? Sometime it will take a little longer than that 5000 to 5500 RPM to get to 20PSI.
Here is a list of my mods
1) DC Sports header (ceramic coated and wrapped)
2) 20G-LT ported on the exhaust side (hot side ceramic coated)
3) eBay style o2 housing (ceramic coated)
4) 3 inch downpipe and cat delete (ceramic coated and wrapped)
5) 3 inch cat back exhaust. No tapering anywhere in the exhaust.
6) HKS RS intake
7) lower intercooler pipe
8) 255 fuel pump
9) ecu flash (NOT specific for the 20G-LT)
10) manual boost controller set at 20PSI
11) Buschur high pressure wastegate
Item in my basement to be installed
1) AEM EMS with speed density setup and boost control
2) Buschur 880 injectors
3) FJO wide band o2 setup
4) Aquamist with direct port injection setup
Old May 11, 2007 | 05:30 PM
kduncan01's Avatar
6) HKS RS intake
8) 255 fuel pump
My Evo is 03 with stock BOV.
Thanks for any help.
Old May 11, 2007 | 05:44 PM
Pd1's Avatar
Pd1
6) HKS RS intake
8) 255 fuel pump
My guess is that you mistakenly bought your FPGreen with the updgraded 18psi actuator (this WGA should only be used on 25+psi applications). I've documented, along with others, the fact that this actuator causes a "boost hump" which hits peak pressure/torque around 5500rpm. Either tune around it or buy the stock WGA and have a more common/natural boost curve that tapers from 4k to 7k.
EDIT: I see that you listed the "Buschur high pressure wastegate." That's your problem.
Old May 11, 2007 | 08:34 PM
sparky's Avatar
You have the Buschur HP actuator on your new turbo right? Also, you should get rid of the cat.
Since I don't think they pressure test the installed WGA's on the bench to see at what PSI they're opening, then you probably have to tinker around with shortening the adjustable actuator rod a bit. Mine was kinda sluggish when I first installed it too.
Old May 11, 2007 | 10:19 PM
kduncan01's Avatar
Pd1 and sparky thanks for the response.
Currently the HP WG has 4 full turns on the adjustmanet rod, if I were to add more turns to the rod, or run like a Forge WG would that help the problem?
Old May 11, 2007 | 10:22 PM
kduncan01's Avatar
I dont have a cat.
what did you do to reduce the sluggishness?
how many turns did you shorten the rod?
kpt6
For Sale - Cars For Sale
Aug 15, 2015 08:08 PM
SuperchargedGTZ
Jun 12, 2013 10:11 PM
04AWDTURBOEVO
84
Aug 16, 2007 09:28 AM
J8dailo
23
Jan 15, 2007 08:16 AM
David Buschur
417
May 23, 2005 03:00 AM
