do i need injectors
Old Apr 29, 2007 | 04:12 PM
thedragon's Avatar
do i need injectors
my set up is this tbe, evc boost controller, downpipe, o2 housing, headers, fuel pump, 272 cams, air intake, hks bov, stage 2 clutch, i blew my head gasket-so i now have a thicker one. stock turbo, stock intercooler, stock intake manifold. my car was custom tuned.psi at 21.5. i blew the head gasket when one of my hoses on my boost controller got loose and the boost flew to 36 then i had a fuel cut. i no that the new head gasket made the comperssion ratiolower making my car slower. so i have to get it retuned but i know i can run more boost now. the problem is how much boost on my stock turbo also am i going to need bigger injectors. i know a bigger turbo would make more sense but ill just beable to afford the retune after all the **** i put in my car.
Old Apr 29, 2007 | 04:15 PM
Steve@NoLimitmotors's Avatar
stock turbo only needs stock injectors
Old Apr 29, 2007 | 04:20 PM
thedragon's Avatar
that was easy thanks
Old Apr 29, 2007 | 05:30 PM
EVOLVEU's Avatar
what about a 2.3L stroker and all the mentioned mods(and more, but stock turbo)?
Old Apr 29, 2007 | 05:53 PM
riceball777's Avatar
who the hell would use a stock turbo with a 2.3 stroker. i never seen anyone do that
Old Apr 29, 2007 | 07:04 PM
EVOLVEU's Avatar
Im definately not the first . Where have you been?
Old Apr 29, 2007 | 07:06 PM
WrX Kila's Avatar
Can YOU SAY ZERO LAG!!
Old Apr 29, 2007 | 07:14 PM
EVOLVEU's Avatar
hahaha, BINGO!
Old Apr 29, 2007 | 11:13 PM
with the stock 2.0 there is already preatty much no lag on the tiny *** stock turbo.
with a 2.3 and all forged internally your really giving up so much with the stock turbo. i mean even with the stock 2.0 the tiny stock turbo cant even keep up with the flow of the engine to maintain boost at the upper rpms.
Old Apr 30, 2007 | 02:00 AM
Evo_7's Avatar
I would say get a Upgraded Intercooler since the stock is not even sufficent...
Old Apr 30, 2007 | 02:04 AM
Cali2MDevo8's Avatar
Registered User
I disagree. the stock intercooler is great for the stock turbo. Upgrading intercooler is one of the last things you really need to do on stock turbo.
jason
Old Apr 30, 2007 | 03:00 AM
Evo_7's Avatar
jason
Stock intercooler after 2 to 3 runs goes into heat soak....
You can also see difference in intake temperatures...
Old Apr 30, 2007 | 03:15 AM
piescrank's Avatar
iv been semi thinking about running a fp greeny with a 2.2 maby 2.3 stroker but i can just see it blowing over the top can anyone piont me in the right direction with information about the power fc as i think i wanna give it a try
Old May 1, 2007 | 03:15 PM
EVOLVEU's Avatar
so... yes on injectors or no???
Old May 1, 2007 | 03:21 PM
chrismnj's Avatar
no
