Swapping out final gear...
Im looking into swapping out the final gear to a higher gear in my ix. What's involve? is it as simple as taking out the rear diff? Any DIY guide out there? I'd searched. No luck.
You are looking for higher top speed and slower accel (dep. on power levels) then (lower gear). Both aforementioned shops can help you there. Yes, you are talking about the final gear. Im picking up what you are putting down now.
http://www.teamrip.com/GENUINE_FACTORY_EVO_PARTS.html
SPEED OF EACH GEAR:
Engine RPM = 7500
4.53 oem final drive - 4.11 HKS final drive - 3.73 TRE final drive
1st = 40 - 47 - 50mph
2nd = 64 -70 - 77mph
3rd= 89 - 97 - 106mph
4th = 122 - 132 - 145mph
5th = 174 - 190 - 210mph
SPEED OF EACH GEAR:
Engine RPM = 7500
all riht i have actually been looking for this info for awhile i was about to post a new topic to find out max speed at each gear and now i know thx. by the way is the buschur racing buschwacker the same thing pretty much (in changin the top speed of each gear) and if so anyone have info of max speed of each gear with thier set up?
SPEED OF EACH GEAR:
Engine RPM = 7500
SPEED OF EACH GEAR:
Engine RPM = 7500
In the link I gave:
"Call or email for details about having your transmission built with this gearing."
Here is Jon's email - jon@teamrip.com
The final drive is before the center diff, so the front and rear diffs are still matching ratios. No other changes required.
The 4.11 set should make the EVO more like a DSM. I personally like the shorter gearing in the EVO, but I can see it being too short for a stroked car with more torque. Even with the DSMs 4.10 gearing (IIRC) first was too short with a stroker, IMO.
my trans & TC is at sheps now. I'm thinking about upgrading the final drive to either 4.11 or 3.73 for more gear in 4th while drag racing. Just waiting for them to actually get to my stuff so I can get an estimate.
What formula are you guys using to figure speeds in respective gears? I've used a few different ones, but I can't seem to match the stock setup.
I've read the Evo IX should hit it's 7k redline @ 106.9 in 4th gear on the stock 235/45-17 (25.3) tires.
.... and 114.5 @ 7500 in 4th.
*edited*
*edited*
IX 4th gear is - 1.029
VIII & IX Final Drive - 4.529
