evo 8 odd hp #?
Old May 3, 2007 | 10:02 AM
EVOL2003's Avatar
evo 8 odd hp #?
is 317 an odd # as far as awhp. mods in sig. how can i get to 330?
Old May 3, 2007 | 10:03 AM
Mad_SB's Avatar
what type of dyno?
Old May 3, 2007 | 10:33 AM
EVOL2003's Avatar
ams il.....i think dyno jet?
Old May 3, 2007 | 10:36 AM
derangedazn's Avatar
What are you trapping?
Old May 3, 2007 | 10:46 AM
mchuang's Avatar
more boost!!!!
Old May 3, 2007 | 10:48 AM
EVOL2003's Avatar
havent taken it yet....only got winter tires only on i think20 or like 21 thought that was pretty high for an 8?
Old May 3, 2007 | 10:50 AM
deadbeatrec's Avatar
10.5 housing, alk, intake
Old May 3, 2007 | 10:55 AM
evo_4U2NV's Avatar
dude... let me say the same thing as i said on another post you replied to from the dude with outrageous HP. first of all his Dyno probably wasnt spring loaded which would read higher HP, second of all dynos are supposed to be used to tune, who cares what #s you get if you Whoop every one on the track or more importantly on the street.
Old May 3, 2007 | 11:09 AM
sonicnofadz's Avatar
I made 350 whp on dynojet with stock 9.8 hotside (stock 03 turbo). Get a good tune and turn boost up to 23 psi.
Old May 3, 2007 | 11:12 AM
El.BlueEvo9's Avatar
On a dyno jet. Sorry man, but that sounds kind of low. Try adding a Down Pipe, and an o2 housing. My opinion anyways. Maybe also a test pipe.
Old May 3, 2007 | 11:14 AM
monies41's Avatar
that looks right on! throw a 50 trim on youll be right around 390ish. That is not low at all for a VIII. Throw a 10.5 on there and some 780 injectors and youll be around 327.
Old May 3, 2007 | 11:21 AM
Ludikraut's Avatar
If you're just shooting for a number, then find a Dynojet that reads higher and have your car dynoed again. If you want more power, then as has also been suggested, get either a 10.5 hotside, or upgrade to an FP Green turbo (need larger injectors).
Whatever else you do, do _not_ just turn up the boost. You can run 23 psi on 93 Octane, but your tune would have to be adjusted.
l8r)
Old May 3, 2007 | 11:26 AM
Cali2MDevo8's Avatar
Registered User
What 272 cams are you running? I have GSC S1's in my 8 and hit 327 on a Dynojet. Graph is in my signature down below!!
mullen
Jul 5, 2010 03:54 PM
Gamble
Midwest Region
Mar 14, 2009 08:29 AM
