How To: Make a High Priced Poorly Designed IC
Old May 4, 2007 | 07:48 AM
  #31
scorke's Avatar
Piping on both ends are custom. Cold side is a modified injen setup, hotside is made completely from scrap, when I bolt it up today I will show you what it looks like.
Scorke
Old May 4, 2007 | 07:52 AM
  #32
deadbeatrec's Avatar
Scorke
i am personally requesting pics of the whole set-up.
Old May 4, 2007 | 09:25 AM
  #33
anjapower's Avatar
scorke power!! scorke's a f@ckin genius BRO!
Old May 4, 2007 | 10:55 AM
  #34
EVO8emUp's Avatar
We use a Bead Form bead roller w/ the crank handle. A rolled bead also makes it easier to slide the couplers on and off when the clamp is loose. Sometimes when you weld a bead, the bead is too large and makes installing/removing the couplers a SOB!
Old May 4, 2007 | 11:40 AM
  #35
Dennis F's Avatar
Originally Posted by deadbeatrec
a weld is more inconsistant than a nice rolled bead would be, so there would be more of a chance for pressure to seap through the inconsistant weld. im sure u wont have any problem with it though. im concerned about the location of the outlets, they look too high for the piping to fit. have u test fitted them yet?
i cant wait to see some pics of the whole set up and some numbers man. i want some 93 octane numbers weather u like it or not.
ps, last time i had Zoe make anything for me, it turned out like shiot, literally!!! yes this is vendor bashing. haha
I agree bead rolling is the way to go.
I was in a pinch and it worked well for the time being.
Old May 4, 2007 | 11:51 AM
  #36
EVO8emUp's Avatar
I've been there!
Old May 4, 2007 | 12:08 PM
  #37
badhabit90's Avatar
Cool
Originally Posted by davidbuschur
badhabit90, that is not the right kind of bead roller for what is trying to be done. We have a large bead roller like that but it is made for doing large flat panel of sheet aluminum or steel. The bead roller used for doing tubing is different. It is important that the bead roll remain very straight around the tubing.
okay it was fixed. clicked on the wrong one. sooo, you use one like this???
http://www.eastwoodco.com/jump.jsp?i...=PRODUCT:beer:
looks like you can get one that will do up to 4" pipe...
Old May 4, 2007 | 12:27 PM
  #38
EVO8emUp's Avatar
Here's the one we use.
http://www.vansantent.com/bead_tool.htm
Old May 4, 2007 | 12:33 PM
  #39
cpoevo's Avatar
Where did you get the end tanks from please? I might just do this myself.
Old May 4, 2007 | 12:46 PM
  #40
scorke's Avatar
I don't think I can show you, it's going to make too much power for you to handle
Teaser, more with IC piping coming.
Scorke
Old May 4, 2007 | 01:04 PM
  #41
Drifto's Avatar
Scorke, make sure that when you bolt up the manifold there aren't any gaps
Old May 4, 2007 | 01:27 PM
  #42
l2r99gst's Avatar
Scorke,
Great job. Quick comment if you don't want to have to beld a bead all the way around the IC inlet/oulet.
Did you ever think of welding a little tie bar to go from the inlet to the IC pipe and the same for the outlet to the IC pipe? That would be a lot easier than welding a whole bead and it would never blow off, no matter what PSI you plan to run.
Eric
Edit: Here's a picture of what I mean. This is from a book by A. Graham Bell called Forced Induction Performance Tuning.
Attached Thumbnails How To: Make a High Priced Poorly Designed IC-tie-bar.jpg
Old May 4, 2007 | 01:53 PM
  #43
PPI's Avatar
PPI
I just saw this thread lol. I am sure that is going to work just fine. What core and size did you go with scorke?
Old May 4, 2007 | 03:12 PM
  #44
scorke's Avatar
Core was 24x14x3.5 I believe I posted it earlier, maybe not?
I had not thought of doing what you have shown but that might not be a bad idea, im confident with t bolt clamps for now and some hairspray
Drifto, don't worry, no gaps
Scorke
Old May 4, 2007 | 05:09 PM
  #45
scottatyamaha's Avatar
Wow, Sam that IC cam out nice and the turbo kit looks awesome. Looks like you are almost done with the car. Let me know before you crank it so we can re-check your cam timing and timing belt. Holla
