Spark Plug Installation
Hi guys.
After following all the procedures of installing new NGK Iridiums (the right ones) my engine is running very rough.
I replaced with the stock plugs and the engine still is very rough.
I have checked each plug inside the block and each one is sparking.
I believe the problem lies within the electronics somewhere, but the connections were made exactly the same and have tested other locations.
Could someone tell me if I may have ****ed the ECU during this install or perhaps if there is another solution? Thanks.
Iridium Option BPR8EIX (NGK) I checked the gaps at 0.7mm and did not cross the coils at all. Going to reset the ECU now and see if it can sort itself out..
A stationary Evo VIII makes a very pretty albeit expensive paper weight!
well in the ngk iridiums, the stock heat range would be 7, so you're one step colder. i don't know about mm, but i always gap mine to .026". and i have regular bolt-ons and didn't see any more knock on the dyno running 7 plugs than i would of running 8's.
.027in (.7mm for you metricheads) is correct.
Check the porcelain for cracks or defects. If all else, take one of the old plugs and test 1 by 1 with the new sparks. If the roughness stops then you have figured out which plug it is. Just some suggestions, good luck!
