what w/g actuator = fp-grn/20g-lt?
Any actuator should be fine at 23 psi. I have the upgraded actuator, haven't tried a stocker to compare. I never go below 25 psi. With 272s it runs 32 psi dropping to 27, with the revolvers straight up it holds 32 psi to redline. Less as I retard the cams. Pretty safe to say the upgraded actuator doesn't blow open against your will.
Kordyte
May 20, 2008 10:27 PM
Aby@MIL.SPEC
17
Dec 1, 2007 05:49 AM
