Head Gasket??
Old May 10, 2007 | 10:28 PM
dxbevo9's Avatar
Head Gasket??
hey guys..my tuner is planning to tune my car for 1.8 bar on pump 94 oct.thats about 26 psi spike then holding at about 23~24psi...he has an evo back in singapore...he has been running that settup for quite some time now however he is recommending i get a thicker head gasket...i am not sure about that..
what do you guys think.
thanks in advance.
Old May 10, 2007 | 10:32 PM
AJsGenerX's Avatar
I don't think you would have to change anything with a stock turbo because most people don't run much more boost over stock setting. Once the turbo is swapped and they run a little more boost, they generally replace the head studs/bolts with ARP studs/bolts (whatever the 4G63 has) along with the head gasket.
Old May 11, 2007 | 04:56 AM
Waz996's Avatar
it's not about whether it will hold or not,, it's about how long it will hold.. One month, two, six?
Better change it..
Wael
